Feb-09-2014 08:16 PM
Mar-16-2014 12:00 AM
Feb-11-2014 06:58 AM
pronstar wrote:
I've got 35's and a 3-inch Carli lift (most of the lift is in the front, rear went up about an inch).
Every toy hauler that I looked at would fit, though you may have to monkey with the hitch height and pinbox a bit.
My Cyclone 3950 has adjustable shackles, I raised them to their highest point just so I could get a bit more bed clearance. I've got about 6 inches of bed clearance now, so no worries about towing over rough terrain.
Feb-10-2014 04:29 PM
Feb-10-2014 03:57 PM
goducks10 wrote:ScottG wrote:
Unless you've added a lot of extra power, with those 35's I think gearing is going to be your problem. If 5.9 auto then you may not get out of 3rd very often.
I went to 32" tires and notice a big difference. I have about 100 more HP and that allows me to use OD.
x2 getting the 5'er level with 6" of clearance would be the least of concerns. I think unless the OP has chipped the crude out of that 5.9 then it's going to feel like the 5'er brakes are on all the time.
Maybe time for a re-gear on the Dodge.
Feb-10-2014 08:35 AM
Feb-10-2014 06:52 AM
Feb-10-2014 02:45 AM
Feb-09-2014 10:12 PM
Feb-09-2014 09:05 PM
rhagfo wrote:Lyrikz wrote:
Purchased a 305v16 and some of the conditions of the final purchase are me test towing and taking it to get it weighed.
Question i have is my tow vehicle is a 1 ton dodge ram 2007. It isnt lifted in the rear, but with the 35" tires on it, am i going to have issues with clearance between the 5th wheel and the bed???
Depends on the 5er, did you measure the distance from the ground to the bottom of the 5er, and the distance between the ground and the top of your bed rail???
It is really just some simple math, if that looks good about 6", then the current height of the hitch plate and the bottom of the pin plate. those should be about the same, with the 5er sitting near level.
Feb-09-2014 08:41 PM
