A/C rooftop unit shroud (updated with photos)
crazyro
I ordered a new shroud based on age and model and the new one is fully enclosed, while the old one has a cutout on the rear (by the fan and filter). It looks like a perfect match otherwise (will know for sure in the morning when I go to replace it), but should I cut out the rear area or just leave as is? I hope I'm making sense. Thank you!
14 REPLIES 14
CavemanCharlie
joshuajim wrote:
I live out in the desert where the sun is brutal on covers. I discovered years ago that a good heavy coat of white paint before installing will double the life. Cuts down on the UV.
Humm,,,, I have a orphan AC that has no replacement parts. Your paint idea might make the cover last longer. Thanks !!!
Now if only I can remember to do it.
joshuajim
RVing since 1995.
MFL
Nomad II
Nomad II
Looks much better than original, and plenty of venting as well. All the years, with the open back, we have seen the results of damaged fins. You could buy and attach a metal cage for protection, years ago, but just makes more sense to come vented, but protected, in the first place.
Jerry
crazyro
Thank you peeps. It's on and seems happy.
deltabravo
DownTheAvenue wrote:
Chris Bryant wrote:
They have just changed the design to make it both stronger and to protect the coils- it's fine to use as is.
X2
x eleventy-billion
Use as is.
DownTheAvenue
X2
Chris_Bryant
-- Chris Bryant
Ivylog
The vents in the back will let enough air out. Install as is.
Upgraded with a 08 HR Navigator 45โ€™...
crazyro
Ok, got the old one off this morning and new one looks just right (slightly taller) and it definitely does not have the cutout in the back. Every single one I've found so far does not so I wonder if it was done by the previous owner? Any thoughts?
Cobra21
Was that a factory cutout in back, or did someone add that? Your new
shroud should be the right one without modifcations.
Chris_Bryant
Leave it as is- but depending on the make and model- Coleman or Duotherm/Dometic- there might be foam pieces that need to be in place to keep air from recirculating.
-- Chris Bryant
opnspaces
Navigator II
Navigator II
If the original cutout is so the condenser (radiator looking part) can breathe then yes you will have to cut the new one out.
2112
FrankShore wrote:
Do you have a question?
Did you miss this Frank?
"should I cut out the rear area or just leave as is?"
crazyro - Not enough information to answer your question. Photos would help.
2011 Ford F-150 EcoBoost SuperCab Max Tow, 2084# Payload, 11,300# Tow,
Timbrens
2013 KZ Durango 2857
FrankShore
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk bรฅt - Dette mรฅ jeg se!
