Bob Landry wrote:
kendive wrote:
I took the fantastic Fan inside cover molding out and you can feel cold AC Air (When AC is on) coming from the sides. So I know that there is ducting in there.
If you took the fan trim ring out and you feel cold air anywhere other than coming out of a ceiling register, then the AC plenum and/or registers, like 90% of the other trailers on the road, wasn't taped correctly at the factory. Go to Home Depot, get a roll of foil duct tape and seal up those leaks or you will forever be posting on here asking why your air conditioner won't cool your trailer. That cold air isn't doing you any good in the ceiling.
"If you took the fan trim ring out and you feel cold air anywhere other than coming out of a ceiling register"
Like I said there is no AC registers back there so the air that I think is being ducted back there has no where else to go but out the sides of the of that area and I can feel it when that fantastic fan trim is off.
No problems cooling the new camper. I have had the AC running at the house while doing some mods to the Flagstaff 25KS and it cools great in the Florida heat.
I installed my Franks Electronics autoformer and mounted in the camper and setup the bypass already...
I guess I could get my hands on a thermal ir camera and it will really tell me where there is cold air up there and where it stops. I have experience with them also for my job.
And yes I can leave the bathroom door open and open the back main vent on the AC Unit and direct air back to the bathroom, but I feel I should not need to do that.
I may call forest river and ask also. I would not think they would come up with a good answer. I feel that it was to save money.
On the slide I found a missing track seal that runs up and down on the camper side of the slide system inside the camper. I have a good dealer and I told them and they just cut me some and I told them I would put it on myself. It was a pain to reach in there and get it on the track and feel better that it is there.
To me the flagstaff quality is lower that the Kodiak 200QB and Aerolite 30BHSL campers we have owned in the past, but we really liked this floor plan of the 25KS. We also lost some storage space because of the Murphy Bed but to me it was worth it. So far we are happy and I did not have to write a check for too much on the difference with the trade got a very good deal. The Kodiak 200QB was a 2011 and we bought the 2014 Flagstaff new off the lot.
