Aug-15-2014 03:46 PM
Aug-21-2014 08:18 AM
v6toy4x wrote:
sears paltinums, decent price when on sale.Same battery as oddyssey. I run 4 group 31s and 270 watts solar. I re worked the bus bar in my panel so I can't run micro AC or refrig on the inverter.
The maintenance free is huge for me as I am lazy not to mention you can store batteries in areas that are not easily accessible since you don't have to monitor the water levels, like in the bed in front of the wheel wells or under the truck making it easy to have 6-8 if you want.
The fast rate of recharge is also very convenient, short run of generator in late afternoon with solar and you can be powered up indefinitely.
Aug-20-2014 04:10 PM
Aug-20-2014 10:17 AM
HMS Beagle wrote:
Here is a fixed link.
They do claim new technology which may have some substance. However they do not guarantee it for any longer than any other lead acid battery manufacturer. One of the limitations of most battery technologies is the calendar time: once the battery is manufactured, a clock starts and it will be junk in some period of time due to chemical degradation even if it is never discharged at all. For good AGMs this seems to be about 10-12 years.
So one question is, how many discharge cycles (and how deep) do you expect to have in the batteries warrantee period? 6 years of every weekend use and assuming 50% discharge each night used is only 624 cycles - which most batteries will tolerate. And that would be severe use for the batteries. Last weekend watching the battery monitor I was only getting down to 92% each night (two 6V batteries, 220 AH capacity). I wasn't running the heater (which is the largest energy consumer) but I was running the vent fan all night, lights, charging the computer, etc. When I run the heater in very cold temperatures (20 deg) I will go down to 80%. Over two nights with no charging down to 60%. But now with solar it is all recharged by noon the next day so never below 80%. My point is that unless you are living 365 off grid with unusual energy requirements you are unlikely to "wear out" batteries in a camper through too many cycles. Instead they will be killed by improper charging, sulfating them by self discharge during storage, or just calendar time.
So logically you should choose batteries based on criteria other than cycle life (assuming good quality in whatever technology). In the camper, I like AGMs mainly due to no outgassing corrosion, no maintenance, and low self discharge rates. Even self discharge is unimportant in a camper stored outside with solar charging.
That said, by all means you should buy those Fireflys and report back to us on how they work!
Aug-20-2014 10:12 AM
Aug-20-2014 09:50 AM
Aug-19-2014 04:37 PM
HMS Beagle wrote:Bob B wrote:
The other thing I am confused about is the # of charge cycle for various batteries.
There is a local battery manufacturer (Firefly) who has a group 31 agm battery and say it is good for 3600 charge cycle at 50% discharge.
These batteries are VERY expensive, but the cost / charge cycle could actually be less if you are in it for the long haul.
I don't know what # of charge cycles a good flooded cell golf cart battery would be.
The number of charge cycles is a very nebulous number as it depends a great deal on care, circumstances, and conditions. I would be extremely skeptical of a claim for any lead acid battery of 3600 cycles to 50% depth. 500 or 1000 is a more typical claim. AGMs will not necessarily last more cycles than well cared for high quality flooded batteries. The claims even for LiFePO4 batteries are only about 2000 cycles, and they are considered to be far longer lasting than any lead acid.
My expectation would be about the same number of cycles from well cared for flooded and AGM batteries, where both were set up with a good temperature compensated 3 or 4 stage charger. Under those conditions, the AGMs will take less maintenance, recharge a little quicker, not outgas or corrode their terminals or anything around them, and stay charged much better over storage periods. The flooded cells will require more maintenance, cost less, and stand more abuse in the form of under or overcharging.
I will note that good quality flooded cells cost quite a bit more than cheap ones, and are closer to the price of AGMs. If cost is the most important issue, then you have to look at watt-hours delivered per dollar spent, and cheap flooded cells probably win, if you are willing to put up with them. They don't last as long but the don't cost much. And there is no point in paying for AGMs unless the charging system is properly set up to take care of them.
Aug-19-2014 04:23 PM
Aug-19-2014 02:55 PM
A couple questions.....do you have an example of a charger that has the ability to equalize a battery?
Are the thin cell Odyssey batteries wet cell or AGM?
Thin cell Odyssey batteries are AGM chemistry.
There are many chargers with an equalize function. Many of the better Magnum and Xantrex chargers have it. Though there is lack of standardization in the industry, what you are looking for is usually called a "4 stage charger" rather than a 3 stage - equalization being the 4th stage. (The stages are: Bulk, Absorption, Float, and Equalization). Some solar charge controllers also do this, although you need a lot of daylight to complete the process. Equalizing is a controlled overcharge, usually at about 15.5-16.5 volts for several hours. It is called "equalizing" because it brings all of the cells in the battery up to the same level. In a flooded battery it also mixes the electrolyte and returns some of the lead sulfate to solution. It also boils some water out which must be replaced afterwards. Most AGM and Gel batteries should NOT be equalized as there is no way to replace the lost water. However Lifeline recommends it on their AGMs under some circumstances.
Aug-19-2014 07:57 AM
Aug-17-2014 12:32 PM
Aug-17-2014 11:02 AM
dadwolf2 wrote:Post the converter make and model.
How can you tell if you have a smart charger or not?
Aug-17-2014 10:26 AM
Aug-17-2014 08:40 AM
Aug-17-2014 12:06 AM
Bob B wrote:
I had heard that the Sears Platinum 31 were made by Odessey, does anyone know if that is true?
