โApr-17-2016 04:38 PM
โApr-23-2016 08:08 PM
โApr-22-2016 08:07 PM
HMS Beagle wrote:That's great information, thank you!
Porpoising is often caused by a difference in suspension frequency, front to rear. Classically, you want the rear suspension frequency to be higher than the front so that it can 'catch up' after a bump. If the rear is the same as, or slower than the front it will contribute to porpoising. With a heavy load in the back, and a trailer beyond, you may have reduced the rear frequency too much. The only way to change it is to reduce the weight or increase the spring rate. All of the various suspension band-aids increase the spring rate. The only one that is easily tunable is air bags.
Shocks can dampen the oscillations and reduce the problem, but don't really address the cause.
There is a pretty good explanation of it here if you are interested in the theory.
โApr-22-2016 11:35 AM
Neither do springs by themselves.
TN Sportsman, your springs are holding some of the weight unless you really add a lot of air to the air bags. The airbags can hold part without holding all. Many of us intentionally spread the load across the springs and airbags. That's why we add extended bump stops to engage the overloads even though we have air bags.
It's all about balancing the system. You can't there with a unique configuration without trying different things.
โApr-22-2016 10:07 AM
โApr-22-2016 10:05 AM
โApr-22-2016 08:44 AM
โApr-21-2016 10:39 PM
โApr-21-2016 09:39 PM
Kayteg1 wrote:
Airbags are rated for 5000 lb @ about 100 psi, meaning 30 psi should give you 1500lb lift. Is that about the weight of your camper?
โApr-21-2016 08:09 PM
TN Sportsman wrote:
On a side note regarding air bags, I just found out that Torklift recommends running NO MORE than 30 lbs. in air bags if you have Stabilloads installed. Since I do, would 30 lbs. even be worth having in my situation, even if I could custom build a set? I'm thinking not. Timbrens may be my best option.
โApr-21-2016 07:57 PM
โApr-21-2016 07:41 PM
Vinsil wrote:
Well in that case I'd be inclined to blame your shocks possibly not able to control your suspension. On top of that, I'd still be leary of spring rates. Yes, the truck could be everything the 89-98 3/4 ton trucks were but it's also a design that is nearing close to 30 years old. Those older trucks did carry weight and campers and you are heavier with the crew cab....you might just be close to taxing the thing. Tires can also contribute to the issues as well. Are you running full/correct pressure and are your tires rated for the weight?
I don't think your trying to do too much with your truck. I think you just need some work/parts to make it comfortable to YOU. Have you had a TC before? What you are experiencing might very well be what it is. Some need a F550 to carry what you are, others do it with a ford ranger. LOL...
Comfort is key, shocks, tires and then maybe some supersprings/timbrens. Should fix you right up.
โApr-21-2016 06:15 PM
โApr-21-2016 04:23 PM
โApr-21-2016 04:01 PM
Vinsil wrote:
Could just be simple spring weights. Too light of rates and your shocks can't control it. Sure, you could have possibly heavier rates than a half ton...in the rear. I'd guess your torsion bars and keys up front just might be half ton stuff and they put a heavier spring pack on the rear to control the heavier axle and added payload. IIRC, the quad steer was geared toward the guy that towed a smaller trailer (not a true 3/4 ton) and made it easier to drive. The rear axle is a Dana 60 center section with Dana 44 knuckles/outters and balljoints. This is much heavier than a standard solid rear axle...so spring weights were raised.
This is a guess so I'd look into it. It may have 8 lug axles but it is still a semi floater rear. I'd check, you might the suspenion is just not sprung for the weight. Shocks will help and 52k might have them worn to the point of replacement as well.
Or...another truck works too. I feel your pain and wanting to keep a low mileage truck. I did and had to band aid mine to work....but it was easier than trying it with what your working with...a heavy 1/2 ton. The guys who buy the new Nissan Titan XD will be in the same bought and fall for marketing. I assume we will have them showing up here in the next year or so.....
