โAug-17-2021 06:36 AM
โAug-21-2021 07:25 AM
fj12ryder wrote:
"The difference is clear!"
Uh, one's used and one's new?
โAug-21-2021 06:32 AM
โAug-21-2021 06:25 AM
1320Fastback wrote:
K&N is trash and will dust your motor.
โAug-21-2021 05:39 AM
โAug-20-2021 08:50 PM
wintersun wrote:
K&N have their advantages for racing vehicles but not for use on paved highways. With my diesel pickup I bought a Fram replacement filter but it was much lower quality and a poorer fit than the stock GM air filter.
What 99% of people do not know is that a filter is least effective when it is brand new and before any "loading" of the media has taken place (same is true for fuel filters). The only way to improve air flow is to reduce the filtering of particles in the air, as with the K&N filters. Not a problem with a race engine that only has to finish the race but not a good choice if you want to put as many miles as possible on an engine.
โAug-20-2021 08:49 PM
โAug-20-2021 01:44 PM
โAug-20-2021 07:59 AM
Cummins12V98 wrote:
FleetGuard oil filters are not made in USA any longer so that is another reason I switched.
Totally get there are only so many battery manufacturers. They do make batteries to the spec people want so batteries can be different.
The MOPAR FleetGuard air filter has changed numbers and is improved to meet the 19 and newer specs.
To give you a comparison of filters my friend had someone change his 13 RAM Fuel filters. When I went to remove the engine mounted filter I no way could pull it out by hand. I had to pry it out. The filters were NAPA and a side by side comparison can tell you the FleetGuard/MOPAR filter has more filter media.
Things may be made by the same company but the quality can be different!
No comparison between the filters. NAPA/WIX and MOPAR/FleetGuard
โAug-20-2021 07:36 AM
โAug-20-2021 05:39 AM
Cummins12V98 wrote:
Nope just wanting the best product available. Example I used to run the FleetGuard Stratopore oil filters but since the AMZ/OIL-Donaldson are a better filter i have switched.
Don't think you will get a better stock air filter than the FleetGuard/MOPAR.
โAug-19-2021 02:54 PM
Grit dog wrote:SweetLou wrote:Cummins12V98 wrote:SweetLou wrote:
No one here even mentions Wix. Why?
Simply NOT the same quality as MOPAR or FleetGuard. I posted the one I run and I think by now you know I am a pick MoFo just order it and be happy!!!
Yup. Going for it but was just curious that Wix wasn't in the mix
Wix is a fine option. Some folks let brand loyalty cloud their recommendationsโฆ.
โAug-19-2021 09:04 AM
โAug-19-2021 08:16 AM
โAug-19-2021 07:32 AM
โAug-19-2021 06:47 AM
