Airbags or Sumo Springs
Xpd77
I just got an AF 811 to put on my 2012 F350 SRW. Even without it being fully loaded with water and stuff, it causes the rear of my truck to sag about 4 to 5 inches. I already have lower stable loads installed and am wanting to add something else to keep it from sagging so much and improve the load handling. Any suggestions on what I should do?
I was thinking of Sumo Springs or Air Bags. Sumo seems simpler to install and use. Airbags seem more adjustable but possibly more expensive and labor intensive. Thoughts?
2012 F350 SRW Diesel. 2014 Arctic Fox 811. Torklift tiedowns, Fast Guns, and Stable Loads.
20 REPLIES 20
SoCalDesertRid1
The tiny amount of tongue weight from a wave runner shouldn't sag a 1-ton truck, at all. These trucks have too wimpy springs from the factory, obviously.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
homefor2
If you are thinking air bags, look at the PacBrake. I just installed them and the quality is impressive. It was not a difficult job at all. A lot of the assembly is done on the bench before you install them. My only complaint is my truck is very unstable (sideways roll) and I am not sure what I am going to change next.
1998 Carriage Conestoga 3742
3_tons
Upon introduction (per Supersprings), Sumo Springs were designed (originally) for the up and down forces encountered on emergency vehicles rolling over varied terrain...Though similar, in my view these forces are not the same as the near constant down force weight of a heavy camper (leaving Sumos in a state of near constant compression), thus I'd opt instead for tembrens... But the 4-5" the drop you mention is substantial, and in the long run a better solution may well require a leaf spring upgrade. I recently switched from Tembrens (after 6 yrs) to adding two new leafs per side (due to rough I-5 So. Calif freeway), and have noticed a worthwhile further improvement. JMO.
Best Regards,
3 tons
More2Explore
In the same boat here with an F-350 SRW and a Wolf Creek 850. The truck has the camper package and will soon have the lower stable loads. It doesn't sag to bad or handle badly but did notice other drivers flashing their lights at me. I'll be towing a waverunner next summer and it drops the back a bit more and the trailer doesn't sit level when hitched up.
I'm leaning toward the airbags mainly due to a very good experience with them on my last rig. Had the basic airbag set (firestone ride rite) with one fill valve per bag for independent adjustment. Did the job with the camper and waverunner or any combination.
If I add them to this truck I think the cab controls with the onboard compressor will be in order.
My Dad and I did the install on the last rig and yes it is a bit labor intensive.....hoping its more straight forward on this one!
Hopefully others will chime in with some more experience and advice!
2014 Wolf Creek 850 SB
2013 F-350 SCB SB 4X4 6.2 L
SoCalDesertRid1
Add a leaf to the springs. If the truck is sagging 4 to 5 inches with Stable Loads and only a partially loaded 811, the truck is insufficiently sprung. It needs more beef in the spring packs.
98Ranger 96Tacoma
20' BigTex flatbed
billtex
As noted...air bags are adjustable...have worked well for us many years now.
B
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
