โOct-04-2016 11:28 AM
โOct-10-2016 05:26 AM
Mike Up wrote:
BTW, if you're using same trailer and same Blue Ox Sway Pro system that you had on your F150, boy were you overloading the receiver hitch of that F150. Looks like you're right at the limit of your F250 hitch.
โOct-08-2016 05:46 PM
Retired JSO wrote:
I use a BOSP with 2000 lb bars and till get a sag in the 8th link. Dry tongue weight just over 660. Does not make any difference if the golfcart is loaded in the toy hauler or not.
โOct-08-2016 10:14 AM
โOct-08-2016 08:50 AM
โOct-07-2016 08:51 AM
โOct-07-2016 05:44 AM
โOct-06-2016 11:32 PM
โOct-06-2016 03:53 PM
โOct-06-2016 06:16 AM
Hannibal wrote:
Are the springs softer or are the blocks shorter to make the newer trucks sit level when empty? I see the same GVWR's offered on Ford's website. My 2010 sits about 2" high in the rear unloaded.
โOct-06-2016 06:10 AM
westend wrote:
This is the manual for the F150, 2013. IIRC, my F-250 instructions said within 1/2" of unloaded. Hey, I could be wrong.
โOct-05-2016 05:50 PM
Lynnmor wrote:Hannibal wrote:
I see the sag complaint a lot too but I'm not getting it. Our 5th wheel had 1900 lbs of pin weight along with 140 lbs of hitch and maybe 100 lbs in the tool chest. The rear of our 4X2 F250 sits a little high empty and when hitched up to the 5th wheel it sat level. It settled 2-3". Some might call that sagging or squatting and look for fixes where none are needed. Maybe I see things different as I've used my truck to carry up to 3300 lbs for work. Sitting a little lower than empty is normal.
The 2011 thru about 2014 had the soft rear springs. They will work, but the rear has to drop till the overloads springs are contacted. I have 860 lb hitch weight and about 400 lb in the bed, also a cap on the bed. I added air bags and run 23 psi in them to level the truck.
โOct-05-2016 04:30 PM
Lynnmor wrote:westend wrote:
I think Ford suggests that when using a weight distributing hitch, the front wheel well should be returned to 1/2" higher than when unweighted.
This is not correct, never does it say 1/2" it is to be returned half way between loaded and unloaded.
See page 275 of your Owners Manual.
Manual
โOct-05-2016 03:24 PM
โOct-05-2016 02:35 PM
โOct-05-2016 10:19 AM
