another do I have enough truck question.
me_camper
My wife has found a new TT she really likes. The uvw is 7,354 and the gvwr is 9,200. My question is my truck in signsture that is rated at 10,000 going to be enough? We only make weekend trips of less than 100 miles. Any input is appreciated thanks.
2005 GMC 2500HD 4X4 Crew Cab
6.0L,4:10
2011 Coachman Freedom Express 296REDS
8 REPLIES 8
fla-gypsy
Seems a reasonable match depending on payload of your vehicle
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
09 SuperDuty Crew Cab 6.8L/4.10(The Black Pearl)
06 Keystone Hornet 29 RLS/(The Cracker Cabana)
badercubed
Weekend trips less than 100 miles seems perfectly reasonable.
2019 Apex Nano 208BHS
2016 F-150 Crew Cab (it's my wife's ride)
Been camping for 37 of my 38 years!
sail2liv
GCWR probably 16000 so pay attention......that will probably be the only limiting factor.....good luck
sail2liv
GCWR....16000 probably.....that is probably the only weight limiting factor...
Good luck......check your manual to verify the 16K......you should be fine with your rig, but be aware of the combined weight of truck and trailer.....you may have to keep stuff that you take light.....plus pull with empty tanks...and half fuel.....
lawrosa
As stated here many times. Load the truck up with family and all gear you will camp with..
Then take it to a cat scale and get the individual axle ratings of the truck.
Compare those #'s to the GVAWR on the door tag. Subtract the scale weights from the tag weights. That will tell you the payload left and what you can town.
You may be suprised at what you get..
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
blt2ski
Moderator
Moderator
Depends. How big of a family do you have? What do they weigh? how much payload is left after the family, dog, in my case the rack for the canoe, generator, cross bed tool box etc. My 96 CC 9200 gvwr rig had all of 600-700 lbs of payload left of 2400 for trailer hitch wt. I would have overloaded my truck with the trailer the op is looking at.
There is more to what is a safe tow setup than tow ratings only!
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
the_bear_II
If you don't want to buy the TT give her this answer "No"
If you want to buy the TT then the answer is "Yes".
Or if you want to buy a bigger truck then the answer is "No but we can get a bigger truck and tow it".
intheburbs
You should be fine. You have enough truck.
2008 Suburban 2500 3LT 3.73 4X4 "The Beast"
2013 Springdale 303BHS, 8620 lbs
2009 GMC Sierra 1500 Denali (backup TV, hot rod)
2016 Jeep JKU Sahara in Tank, 3.23 (hers)
2010 Jeep JKU Sahara in Mango Tango PC, 3.73 (his)
