โSep-05-2019 11:41 AM
โSep-09-2019 12:12 AM
โSep-08-2019 03:32 PM
Grit dog wrote:
^You may have a good reason for that, but my experience in many brake jobs is that there is no harm in anti seize for the mounting bolts. Only benefit for the next person having to remove them.
โSep-08-2019 03:01 PM
โSep-08-2019 12:40 PM
โSep-08-2019 09:35 AM
mich800 wrote:
The OP noted caliper bracket not pins or caliper bolts. They do tend to be stubborn. I donโt think anti seize will hurt anything.
โSep-07-2019 07:21 PM
Grit dog wrote:
True statement, fasteners are cheap, but the labor to replace all the wheel studs on a vehicle every couple years? Holy carp! Be financially advantageous to never rotate your tires or just trade it in when your alarm clock says replace perfectly good wheel studs.
I will give you this, I've had a couple vehicles that the lug nutz basically wore out.
Haven't replaced a lug stud in idk how many years and those broke due to rust or a bad/loose wheel.
โSep-07-2019 09:41 AM
STBRetired wrote:Grit dog wrote:
Lol, really? By way of all your experience with engines, one would think you'd understand clamping force, slip critical connections, yield and non yield tensile strength, torque as it relates to tension etc.
You seriously replace the brake caliper bolts after using them twice and your wheel lugs after 4-5 tire rotations?
I don't believe you....
Yes, I actually do. It's not like I pull the calipers off every week. A set of pads usually lasts at least a couple of years. I've had several broken wheel studs which I attribute to the grease monkeys at the Ford dealer running the lug nuts down with their air impacts, even though I specifically ask that they hand torque them. I don't drive a lot of miles since retiring so I only need 1 or maybe 2 tire rotations per year. Working on the dragster has made me a bit of a nut when it comes to fasteners. Fasteners are cheap compared to what can happen if they fail. At least I don't safety wire everything on my car like we do on the dragster. Guess I'm just a bit extreme.
โSep-07-2019 09:38 AM
โSep-07-2019 09:26 AM
โSep-07-2019 09:24 AM
fj12ryder wrote:
Okay, that makes sense. Thanks.
Almost sounds like the bolts were undersized and stretching, then loosening up. The loctite wouldn't really address the issue, but it would keep the bolts from then falling out.
Pretty rare for caliper bolts to just fall out, but not unusual for the recommendation of loctite on those bolts. I agree that blue should be perfectly fine in most circumstances.
โSep-06-2019 06:33 PM
โSep-06-2019 05:54 PM
STBRetired wrote:
On my personal vehicle, I follow that same rule for any safety related items like brakes and suspension / steering. Anything else, like wheel studs, I will usually go 4 or five torquings before replacing.
โSep-06-2019 04:03 PM
โSep-06-2019 03:52 PM
