Anyone done one of these?
pjay9
I have always wondered about these units and wonder if anyone on RV NET has done one?
TRUCK BODY
I happen to run across the red one in OR a few years back, now I have discovered who makes them...not far from Lance in Bakersfield.
2005 Lance 1161, 2004 Dodge CTD 3500 Dually 19.5's Stabiloads Roadmaster Sway, 2009 20' Raider 185 Pro Fish 90hp & 9.9 Yamaha vintage Penn elec.downriggers EZLoad roller trailer
19 REPLIES 19
deltabravo
enblethen wrote:
Would be great in many cases for storage.
Ditto!
That lack of storage in a camper is one minor drawback. Things like extension cords, portable generator, water hoses, etc would be right at home in a utility body.
Bedlam
Moderator
Moderator
The Torklift FastGun .45s or the Basic SpringLoads with Derringers are the best spring loaded quick release options for flat beds. I'm still contemplating how much twist there is in a flat bed and whether fixed turnbuckles would suffice.
The popup is using a bumper mount anchor in the rear, but I cannot see the front.
jimh406
You can see the tie downs in the popup picture if you look closely.
Bedlam
Moderator
Moderator
The camper is tied down to the utility bed (requires anchor points) or flat bed (uses stake pockets or load rings). It will typically be an 18" or shorter connection. I'm actually in the process of researching my tie down fasteners right now for a flat bed.
stevenal
Nomad II
Nomad II
Where do you tie down the camper?
'18 Bigfoot 1500 Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
Bedlam
Moderator
Moderator
$8-10K is typical for service bodies. $3-6K for a flat bed with utility boxes.
pjay9
This is the Brian I am chatting about: 2006 LanceMax 1191 2005 C4500/Kodiak 4x4....sorry a Bear Truck...sorry for confusion.
SorryDangDog
This outfit makes a composite service body:
BrandFX Service Bodies
Can't tell you much more about them other than someone had a Hallmark Pop-Up put on one.
Here it is:
pjay9
A 1000# would have some impact for sure. if they are 10K$ that is most likley out of my range unless I hit the lottery...then I buy a trekking vehicle. :>)
sky_free
I checked into this a while back and they are made from steel and weigh over 1,000 lbs if I remember correctly, so requires a lot of truck.
2017 Escape 17B, 2012 VW Touareg
Butch50
pjay9 wrote:
jarends wrote:
I have a flat bed I had built and instead of all compartments, I went with under bed storage for permanent things, air com, tools jacks and on Sides full length al w 2 doors so there is full room to put long, short or what ever, More storage than I have ever used even on month trips
Would you post some pics please. I have seen Brian's on the Duramax chassis. I like what he has done, he has 4x4 an am 4x2 dually...I like the easy entry of being lower to ground with the side entry of the 1161 and it is even lower as the 61 does not have a basement when compared to 81/91, if I am not mistaken.
But would like to see your unit. THX
I believe Bryans utility bed is mounted on a F550 CC Ford not a Dmax.
Butch
I try to always leave doubt to my ignorance rather than prove it
2021 Winnebago View
805gregg
It would have to be aluminum to be light enough
2003 Dodge Quad Cab 3500 SRW LB Cummins diesel, Banks Six Gun, Banks exhaust, Mag hytec deep trans pan, and Diff cover. Buckstop bumper, Aerotanks 55gal tank, airbags, stableloads Bigwig stabilizer, 2003 Lance 1071 camper, solar and generator
egarant
I called them about 10 months ago, the average cost out the door painted white is around $10,000.
Do realize that it is custom made to your TC, so good luck if you ever decide/have to change out TC's.
2021 FORD F350 dually 4x4 with 4.30 gears, 013 Eagle Cap 950, 480 Watts Solar, 3K Victron Multiplus II, Victron smart DC-DC charger, Victron 100/30 solar controller, 250 amps of lithium batteries by LifeBlue
pjay9
