โOct-29-2022 07:48 PM
โDec-08-2022 07:01 PM
โDec-08-2022 08:56 AM
โDec-06-2022 02:31 AM
theoldwizard1 wrote:
Not a "general purpose" caulk or one that you can apply layer upon layer, but butyl tape works well. It is not expensive and easily and cleaning removed.
It is designed to be used as a "bedding compound" where the item you are trying to seal can be removed in order to replace the butyl. Used on many boats around windows because of the enormous amount of effort required to remove old caulk.
โDec-06-2022 12:39 AM
โDec-05-2022 03:41 PM
โNov-14-2022 04:16 AM
โNov-13-2022 05:20 AM
โNov-11-2022 03:13 PM
โNov-10-2022 10:36 AM
Grit dog wrote:Speaking of replying to hear yerself speak....:R
So you seal your RV exterior with silicone caulking, or replying to hear yerself speak.
Bottom line, don't use silicone, use a urethane product or something intended for the use.
โNov-10-2022 03:11 AM
โNov-09-2022 12:27 PM
Bobbo wrote:4x4van wrote:rerod wrote:Yet a Youtube search says the opposite.
Ive learned on RV forums new silicone caulk will not adhere and seal to old :h...
And, you can believe everything you read on the internet. Including on this forum.
โNov-09-2022 11:54 AM
JIMNLIN wrote:And yet I've never seen the words "Acetoxy" or "natural cure" on a tube of silicone. I've always bought simple "100% Silicone" (not "siliconized caulk"), and it has indeed smelled like vinegar. Yet your description suggests that is not what should be used outdoors, and you really don't clarify which one will (or won't) stick to itself. :S
Simply put ...far more people have had issues with certain types of silicone's than have had good luck with them.
We also have service experts tell us what they found works and what didn't.
Not all silicone is the same.
See my reply above for a explanation why some silicone products stick and other didn't.
Acetoxy vs natural cure silicone....there is a difference in adhesion quality according to the pros that use sealants in their line of business.
โNov-09-2022 03:32 AM
โNov-08-2022 11:08 AM
