Are the 2016 Ram HD’s Output Figures Bogus?
45Ricochet
CLICKY
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
89 REPLIES 89
FishOnOne
Perrysburg Dodgeboy wrote:
FishOnOne wrote:
I can tell from street experience loaded and unloaded that ever time a LAM owner tried to out run me, my Ford spanked them really bad. Everyone I've talked to who have driven both trucks including myself will say the Ford feels stronger than the ram.
The only one LAM is you and Ford. Spin this Troy " On the flipside, most of Dearborn’s pickups are compliant with this rating, though not all. Levine said, “Since 2013 all new Ford vehicles are rated according to J2807.” This includes the 2015 F-150 as well as its monstrous F-450. However, the blue oval’s F-250 and F-350 trucks are not currently compliant, something that will be rectified in the near future." LMAO every Ram truck is compliant and I believe all of the GM trucks are now also.
Don
don,
Not sure what J2807 has to do with RAM's engine output!
Control the Angst...:R
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Cummins12V98
Don
He tends to omit certain things.
Interesting comment on the 68RFE dead pedal. NEVER had it with my 11 HO Dually or with current 15 with Aisin trans.
Only dead pedal comments have all been associated with the Aisin I have heard of.
The cummins is not a high Erving engine and does NOT seem fast.
Ask MeAgain if he thought we were doing 93 at the end of the freeway on ramp. I sure did not think so until I looked at the speedo. The Cummins is a sleeper it just hooks and pulls.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Perrysburg_Dodg
Don
2015 Ram 1500 Laramie Crew Cab SWB 4X4 Ecodiesel GDE Tune.
RobertRyan
Hannibal wrote:
Who cares what the advertised HP is. I'd like to see them tested at their full GCWR up the grades. Lets see if they live up to the hype.
Correct,at least the grades are the same
FishOnOne
IdaD wrote:
The 2015 ford definitely feels faster than the Cummons. That was my impression anyway. I don't know that it necessarily felt "stronger" though. They actually feel pretty different. The Ford almost behaves like a gas motor as it revs up a lot quicker and higher while the Cummins is louder and spools up more deliberately. They were both plenty strong and fast to me so that was a non factor in my decision. Other factors swayed my decision.
I agree they definitely feel different and I would add a big part of that comes from 68 tranny hunting for gears and the dead pedal was absolutely horrendous to the point it almost felt dangerous when pulling out into traffic.
I haven't driven the '15 Fords but the reports I've read say they have a bit more turbo lag than the '11-'14 but the power feels stronger.
IdaD
2015 Cummins Ram 4wd CC/SB
FishOnOne
Cummins12V98 wrote:
I can tell from personal experience on a Las Vegas Dyno the RAM puts a larger percentage of advertised HP to the ground than the Ford does. I would guess the GM would be more also. Ford had a typical 20% loss to the rear wheels compared to the Cummins at 13%. 11 HO Cummins VS 12 PS Diesel.
Cummins12V98
Bionic_Man
Farmerjon wrote:
IdaD wrote:
I have no idea how accurate the numbers are, but all three of the big diesels have plenty of power. I wish they'd start trying to one up each other on fuel economy now and stop chasing more power.
X2
Although it doesn't really effect me as I won't be looking for a new truck for the next 10 to 15 years and I will be 80 to 85 years old at that time.
Well, if you really believe that, you should look at the new 5.0 cummins in the Titan.
Although I doubt people really feel that way.
Case in point, the person who says x2, yet puts the hp and tq numbers of his engine in his signature.
People want power. I'm no different.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
ShinerBock
BenK wrote:
and stop that GCWR on a steep (7% or whatever is the max spec) and get it going again...SEVERAL times...
Actually that is what the J2807 tests does in the braking portion. Although I don't know why I am saying this to you since you have me on block and you will never read it.
2014 Ram 2500 6.7L CTD
2016 BMW 2.0L diesel (work and back car)
2023 Jeep Wrangler Rubicon 3.0L Ecodiesel
Highland Ridge Silverstar 378RBS
spoon059
Madhatter1 wrote:
The numbers are bogus. My 14 is a sad sack computer controlled never gonna make rated HP contraption. Press the pedal and it works like an HVAC chiller. It will load up and start to make power but do it on its own preset parameters. Parameters which have NOTHING to do with real world driving. A good example is my truck does quite well hauling the 14.5K loaded toyhauler but with a 4-5K cargo trailer in Montana hills it IS A PATHETIC POS THAT CAN NOT FIND THE RIGHT GEAR OR PRODUCE THE EXPECTED POWER to drive normally. Choice is a slug or drive it floored and back off and then back on.
Bottom line is the advertised HP and TQ is something that it could potentially make under some rare circumstances. Very rare. Maybe unique.
Huh?
2015 Ram CTD
2015 Jayco 29QBS
BenK
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
Farmerjon
exactly
2015 F350 Lariat CC LB 4x4 DRW 6.7, 6sp auto, 3.73
2000 F350 lariat SC LB 4x4 DRW 7.3, 6sp manual 3.73
1987 F250 Lariat SC/LB 4x4 SRW 460 4sp stick 4.10
1995 Jeep wrangler
99 Star Craft 953
Hannibal
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
bucky
Horsepower can kill us, too much money or the wrong pretty woman can get us killed. 🙂
Puma 30RKSS
