As to camper weight, what does this sticker indicate?
RKW
Ryan
  • 2015 Ford F250
  • 2015 Rockwood Signature Ultralite 8280 WS
  • Dual Honda EU2000i Generators
    The wages of sin are death; but after they're done taking out taxes, it's just a tired feeling.
21 REPLIES 21
Grit_dog
Navigator
Navigator
Supercharged111 wrote:
A guy I race with has a 2015ish F250 with a ~2500# Arctic Fox and pulls his heavy ass 24' enclosed car hauler with walk on roof. All he has is bags, but he does say he wishes he had that F350 upper overload. Otherwise no troubles for the last few years of use.
He's haulin more than that, unless that AF camper is gutted. More like 4klbs for the shortbed models and the no slide model.
Bag's will hold it up for sure. Having a heavy tongue trailer with a ball coupler helps stability/body roll. It very likely handles better with the heavy trailer on back than no trailer.
Supercharged111
2007 Lance 1131
1997 GMC K3500 crew cab supercharged dually
JIMNLIN
Tell part of the trucks actual load carrying ability. AS others have said a pickup truck carries just about all payload over the trucks rear axle (6100 rawr) which will be around 3000 lbs in most cases. A RAWR is the lessor of the tires/wheels/rear axle assy/rear spring pack. Todays pickups generally the wheels or rear spring pack is the weak link. Years ago it was OEM 16" LT235/85-16 E at 3042 lbs capacity as the suspension weak link.
Another player in the payload arena for the F250 is if it has the heavy service package option. This package upgrades suspension to the same as the F350 SRW trucks.
The F250 won't have any issues carrying a 2155 lb wet weight truck camper you mentioned.
specta
Here's the sticker on my truck that lists max payload.
Kenny
1996 Jayco 376FB Eagle Series TT
1997 Jayco 246FB Eagle Series TT
1976 Ford F-250 4wd Mercury Marauder 410 - 4V
Regular cabs. The best looking trucks.
specta
Kenny
specta
Makes me wonder if it has a snow plow pkg.
Or is a 5400 lb front and a 6100 lb common on a Ford with a 10k GVW?
Kenny
Lwiddis
โ€œAs to camper weight, what does this sticker indicate?โ€
Not difficult. The maximum vehicle weight.
RKW
Terryallan wrote:
It also tell the rear gear ratio if you know the codes
From the "CJ" code I'm fairly certain mine is 3.55 limited slip.
Ryan
  • 2015 Ford F250
Terryallan
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
RKW
Mike134 wrote:
RKW wrote:
Thanks for the replies.
I think I need more truck. I'm looking at a Lance 825 with a Wet Weight w/Std. equipment of 2155 lbs. Still, I understand I need to weigh the truck.
10,000lb means you have a F350 single rear wheel no?
No it's a F250. SRW.
Ryan
  • 2015 Ford F250
Mike134
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
2oldman
As mentioned, GVW= 10,000.
That's the maximum your truck should weigh going down the road. That would do it for me.
Grit_dog
Navigator
Navigator
That sticker indicates that in the 18 years you've been a member of this forum you haven't read or retained ANY of the 10,000s of "gvw", "axle capacity", "tire rating", "what will me truck haul", "how much can I carry" threads.
RKW
Ryan
  • 2015 Ford F250
