Atwood Water Heater not heating
Jay_Flight_33RL
Our Atwood Water Heater in our 2011 Jayco Jay Flight G2 Series M-33 RLDS has been acting up. This is our fourth season with this wonderful trailer. The hot water was HOT over the first three seasons. At the beginning of this season it seemed as though it wasn’t quite as hot but bearable. During our last trip this past weekend we didn’t even need to mix with cold water to take a shower. Steady stream out the hot side. We could feel spurts of hot water during a shower but nothing like we are accustomed to. Has anyone had this experience? If so, what did you do to fix it?
Mark
2003 Dodge Ram 2500 Quad-Cab 5.9 L Cummins diesel
2011 Jayco Jay Flight 33RLDS G2 TT
Equal-i-zer®'s 4-Point Sway Control
Goldline RV Cover
10 REPLIES 10
Jay_Flight_33RL
Issue resolved. The bypass valve was indeed open. It’s been that way all summer. The colder outside temperatures this past weekend made that more obvious. Thanks to all for your suggestions and willingness to help.
Mark
Goldline RV Cover
pnj442
Slightly open the PRV. If the wagter is hot, there is nothing wrong with the heater. Probably as others have said, the bypass valve.
Old-Biscuit
First...
Were you using electric or gas?
Did red light on panel come on?
Does the gas burner come on at all?
IF burner comes on.....how long does it fire before turning off?
After it fires...pop open PRV (press relief valve) in outside compartment.
CAUTION: WATER SHOULD BE VERY HOT
*Check valve on backside of water heater tank in hot outlet line sticking close/plugged restricting hot water flow
*Bypass valve open---not fully closed on line that connects cold with hot on backside of water heater tank
*Showers not being turned off at cold/hot knobs just with button on handle will cause warm water due to mixing in shower faucet
Course that is IF water heater is turning on
retiredcamper20
I vote for the bypass valve. I had the same symptoms once and we discovered the bypass valve was in the wrong position. Hope it's a simple fix for you as well.
mhardin
Bypass valve.........
2013 Ford F-350, 4x4, Crew Cab, Long Box.
2001 Jayco Eagle 266 FBS.
2014 Heartland Elkridge 37 Ultimate.
FrankShore
Did you service the water heater once a year as suggested by Atwood?
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk båt - Dette må jeg se!
nomad297
Nvr2loud wrote:
ewarnerusa wrote:
If there were spurts of hot water, then maybe the heater is still working as well as before but you might have outside shower taps open or winter bypass valve in open position.
Yeah... check the bypass valve!
This IS the problem.
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
Nvr2loud
ewarnerusa
Aspen Trail 2710BH | 470 watts of solar | 2x 6V GC batteries | 100% LED lighting | 1500W PSW inverter | MicroAir on air con | Yamaha 2400 gen
Nvr2loud
Either:
1) Faulty Thermostat
2) Burner not firing on high (gas valve issue)
3) Plugged burner tube / exhaust port
