Auto Leveling on a TT??
kfp673
Has anyone ever seen a TT that comes with it or has anyone added an auto leveling system to their TT? Has been offered on motorhomes for many years and over the past few years has found it's way onto 5er's and toy haulers as well. I don't see why not on TT's. For me it's not a lazy thing as much as it is something to save my marriage 😉
I'm kidding! But we do stay at a lot of state parks and other places with very un-level sites and by the time we finally get it level my wife is ready to kill me. I can't stand a trailer not level!! Last year we were on a trip and had a very un-level site that made us build up leveling blocks 3-4 high. Took me 30 minutes of playing just to get it level. Was not a big deal with our old 19' hybrid but with a 33' TT it can be a real pain. I would gladly spend a few thousand extra on my next TT to just push a button and be done!
What are your thoughts!
17 REPLIES 17
azpete
i have seen hwh systems installed on regular travel trailers. there are limiting factors in all jacks, because of the short distance between the frame and the ground. the front isnt the problem. the rear jacks have to be mounted behind the rear axle to keep from twisting the frame. please feel free to call me at 602-549-3638 if you would like to talk. i do work for hwh, but i do not sell the jack systems. i only repair them. i do a lot of work with camping world.
carringb
Old-Biscuit wrote:
side to side level.........some boards under low side
front to rear.......tongue jack
crank down front rear stabilizers
DONE......15 mins.
With Auto-levelling:
Push button
DONE.... 2 mins.
Really though, while leveling the trailer isn't a big deal, its actually one of my main gripes with the trailer. I will be upgrading to a leveling system shortly. Most of my stays are only one night, so the leveling and raising of the manual jacks adds up to some hassle, and I'd rather spend the time elsewhere.
2014 ORV really big trailer
2015 Ford Focus ST
kfp673
skipnchar wrote:
Your stab jacks are not to be used for leveling anyway. Use material under wheels for side to side leveling and the tongue jack to level fore and aft. If you use stabilizer jacks to level your trailers frame can become bent/damaged so self leveling is not a good idea.
Good luck / Skip
Understood. This is why auto leveling systems typically have jacks directly behind the axle not at the very rear of the trailer like stab jacks, and they typically both lift together not one at a time. Personally, I think it is something the industry should look at including on more TT's. Based on responses to this thread I am seeing systems that cost roughly $3k that appear to be true 4 point auto level systems both hydraulic and electric options. If I was buying a $20,30,40k travel trailer I would be happy to spend an extra $3k for this option. Just my opinion. Thanks again all!
TerryandKim
Get These!
Then use tongue jack for front to back and put down the stabilizers.
1999 GMC Sierra 1500 ExtCab SLE 5.3l 3.73 - Curt WD, airbags
2010 Jayco JayFlight 26BHS G2
1 Wonderful Wife!, 2 Great Boys!, 1 Goofy Basset Hound (Floyd),Oh, and me.
skipnchar
Good luck / Skip
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
Huntindog
Be careful. TT frames are all over the map strength wise. None of them were designed with a self leveling system in mind. I do think it may be possible to do it, if your TT has a stout frame. I would lean towards the 6 jack systems to better distribute the weight.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
kfp673
Thanks all. I will look into some of these. To some of the replies regarding standard levelers, I appreciate it but I am talking about areas that are seriously out of level. Boards, leveling blocks, etc all kick out if too high. I have had travel trailers for about 10 years and am pretty good at setting up quick in normal circumstances but we have some state parks and I go to some music festivals where I end up on a hill or on a site clearly designed for tents and it gets frustrating. Thanks again all
Obewan
Big Foot has a hydraulic system for TTs.
2015 DRV Mobile Suites 44 Lafayette Walden
2014 Ram Laramie 3500 dually
Teamfour
^^^This. I love mine.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 locker, 3,295 Payload
2014 Salem Hemisphere 282RK 7.8k lbs loaded, Equal-i-zer WDH
ScottG
You might give Anderson Levelers a look. THey make leveling a TT about as easy as it can be without installing expensive automatic stuff.
dockmasterdave
Side-side jacks?
I assumed he meant some boards under the low side tires.
I just cut two length of 2x6 with a 45 degree bevel on the end.
I can see roughly how far out the trailer is in place, pull forward a couple feet, put the boards down and back the trailer up onto them.
1 board brings me up 1 1/2", if not enough add the second board.
Then the hitch jack for leveling front to back, and stabilizers to just beyond snug.
I have also used them to change a flat.
Pulled the good tire up on them, changed the flat, and drove away.
Multi purpose.
2014 F 150 ecoboost
2008 Chrysler Aspen
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
93Cobra2771
Ultra Fab also has some available.
Thread here:
Clicky
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
dodge_guy
As long as the 2 side-side jacks are placed in the middle of the trailer it should work.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Old-Biscuit
DONE......15 mins.
