Mar-23-2022 11:08 AM
Mar-27-2022 07:04 AM
Mar-26-2022 07:20 AM
Mar-26-2022 04:08 AM
Sport45 wrote:JRscooby wrote:
I can see how that would work. OTOH, the valve in toilet starts to leak, water drains thru the overflow, overfills bowl, and down drain. Can waste a lot of water but that is the only harm unless you have to pay a plumber to replace it.
A similar system is the float/needle seat system in a carburetor. When that leaks gas can get on top of engine, but it also dumps into the engine stops it from running right (if at all). Fuel pump stops putting gas to carb. Fire is a possibility, but most likely expense is carb rebuild.
What happens if you park the truck with a leaking float valve.
BTW, in my lifetime I have replaced over 100 toilet tank valves, and rebuilt even more carburetors. Failure is not a far-fetched idea.
If it's overflowing I'll likely smell the diesel when I get out of the truck, notice the spots of fuel blown up on the back of the truck (yes, I know what a fluid leak does to a moving vehicle) or see the puddle under the truck. Just like other failures I've dealt with I'll close the manual valve until I get a chance to repair or replace the float valve. I won't be losing any sleep waiting for the failure to happen though.
Mar-25-2022 08:41 PM
Mar-25-2022 03:34 PM
I'm hard of understanding here. If you have a line from 1 tank down to another, the fuel will flow. And if the level of fuel is above the fill neck of the lower tank, or any vent, what will stop fuel from coming out the vent?
Mine has a float valve where it ties into the main tank fuel fill line. It doesn’t let any diesel in once the tank is full. I suppose it’s similar to the valve that stops water flow once your toilet tank is full.
hotpepperkid wrote:
I want to hear the rest of the story.
Mar-25-2022 02:22 PM
JRscooby wrote:dedmiston wrote:Grit dog wrote:Lwiddis wrote:
Aren’t gravity fed gasoline tanks illegal?
Aren’t you trying to start an argument, or just typical passive aggressive response?
It's just Lwiddis being Lwiddis.
Sorry. I do not see anything in the OP that tells what fuel the pickup uses.
And it is a fact there are a lot of regulations, (impact protection, vaper recovery, whatever) that apply to gasoline tanks in vehicles. Most tanks sold to mount in bed are advertised diesel only to avoid the regulation.
For many, is it legal is a valid question.
Of topic, but kinda funny.
Contractor I did a lot of work for had a few weeks work, about 60 miles from home. I decided to leave 3 trucks on site, just sneak 1 into town every day for fuel. Contractor could not fuel all equipment on job with the transfer tank mounted on his truck, so we strapped a tank down in my tool truck.
One morning, I ran into a DOT check on my way in. When stopped, had 3 things on my mind; 1, likely over my licensed weight limit. 2, real close to limit on licensed distance from home. And 3, the straps holding that tank did not have a load limit label. LEOs 2nd question, behind DL, registration, and insurance, was "What kind of fuel in tank?" Now I'm not thinking about the step by his knees when I said "Dyed, off road diesel" He was mad when he stuck his wand in my gas tank, and the plastic dissolved. At the time I had a 460 in that old F500.
Mar-25-2022 01:19 PM
Mar-25-2022 12:30 PM
Mar-25-2022 10:20 AM
Mar-25-2022 10:09 AM
thomas201 wrote:
When I had diesel, I used gravity feed. With gas, I have to pump. I would not pump diesel, because if you leave the pump on it will have to go somewhere after the truck tank is full. So, if you pump, you need a return line to the deck tank. Just saying.
Mar-25-2022 06:30 AM
Mar-24-2022 08:04 PM
Mar-24-2022 09:30 AM
Mar-24-2022 08:11 AM
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • <\br >Toys:
