Awning cover
bdlaise
Came up with a different way of protecting my awning and keep the tree debris out of the valley between the trailer and the awning while is rooled up.
I looked at the Pro-tech product that is advertised in the trailer life and motor home mags. I wanted something like that, but did not want to pay $100.00 either. So I looked at the local home improvement stores and only found very heavy gauge PVC for plumbing and drainage. So I looked at the heating and cooling ducting, found a 5 ft by 4" sections that would slide over the awning, just like the way the Pro-tech product says it does.
The to keep the debris out of the channel from between the trailer and awning, I picked up the drip edge that is normally placed under the your houses roof's shingles at the edge by the rain gutter. To accomplish this I lined the drip edge while the ducting was on the awning, to cover the gap. I just need to finish completely painting it.
See the pic attached
4 REPLIES 4
pappcam
Hmmm...
My awning tube lays against the trailer below where the awning attaches to the trailer so there's no little valley at the top of the awning. I assumed they all worked this way.
2023 Grand Design Imagine 2970RL
2011 F150 XLT 5.0
bdlaise
The cost was just under $50.00. I pop rivetted the drip edge to the duct tube. I butted the edge of the drip edge to the side of the trailer just under the lip of the roof. The weight of the ducting which isn't much, hold it in place. The tubes sleeve together to make a continuous covering for the awning. The only downfall, is the I can't keep it on for travel. I used 4" diameter, I could have gone with the 3" but did not want to take a change with ripping the fabric.
LakeN
are you saying the ducting slides over the awning and that holds the piece ovet the awning crack?
'16 Winnebago Minnie Winnie 25B
'14 Ford Focus Titanium Toad with Blue Ox tow system
TucsonJim
That looks great. Thanks for adding pics! What did the whole set up cost you?
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
