Awning is Holding Water
dee74
I always make sure my awning is dry before I roll it up and put my RV in storage. Every time I unroll my awning water pours out, I can only assume this is rainwater. My storage area is uncovered so I assume this is rainwater. So far I keep my awning pretty clean but I am more worried about this trapped water when the temperature is below freezing. Will this trapped water damage the awning? Is there any way I can prevent the water from getting in the awning?
11 REPLIES 11
swimmer_spe
It is either rain getting in, or condensation.
If you wash the awning once a year, you should be able to fight off the mildew.
Mark_and_Linda
My neighbor gave me some covers that he had ordered for his but they did not fit. I have used them to help keep the mildew off of the outside but I still have water inside. I make it a point to try and open my awning whenever I can just to let it air out some. I think I will try and cover the ends to see how much that will help.
Mark
Arn
Freezing isn't an issue. I'm in eastern Ontario where it is below freezing from December till March & the only problem I end up with is mildew.
Arn
1958 Me
1963 Her
2015 Jayco Jay Flight 33RLDS
2020 Silverado LTZ Crew, 5.3 Max Trailering Pkg.
wbrown62
The soda bottle cap idea does NOT work. I have tried it numerous times. Have even done the rain cover mod using rain gutter which extends beyond the bottle capped ends. The awning is still soaked when it is unrolled. Wet is wet whether it is rainwater or condensation.
2011 Keystone Bullet 246RBS
2000 Chevrolet Silverado
gunner65
old_guy
once I read to take the plastic liter pop bottles and cut off the top and bottom and then cut the full length and place them over the awning to form a barrier to keep the water from getting into the awning. only problems it takes a lot of bottles to do this.
Drbolasky
tvman44 wrote:
I don't think the water freezing would cause a problem but it sure does prompt mildew problems.
Mildew is the bigger issue, IMHO. Scrubbing the awning is my least favorite RV-related task and I try to do it on a hot day because there's no way to scrub the underside of the awning without getting soaked.
Spring through fall I will periodically extend the awning to let it dry out and head off the mildew problem.
Doug, Linda, Audrey (USN) & Andrew
2008 Sequoia SR-5, 5.7 L, 2000 Coachmen Futura 2790TB Bunkhouse, Dexter E-Z Flex Suspension, Reese W.D. Hitch/Dual Cam Sway Control, Prodigy Brake Controller, McKesh Mirrors
:B
therink
All awnings on 6 different rvs I've owned take on water in rain. Just the nature of the beast. I believe water wicks on from the ends and also condensation.
When not using for a lengthy period, I try to unroll it so it dries out periodically so mildew does not form
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
tatest
Mine fills during covered storage, so it is not always rainwater. Sometimes condensation?
Tom Test
Itasca Spirit 29B
Dick_B
Search this Forum for `awning' then search the results for `condensation'.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
tvman44
Rain water seems to wick into the awning a lot, common problem. You would have to cover the awning somehow to prevent this. Our 5er is stored under a cover so I have no problems. I don't think the water freezing would cause a problem but it sure does prompt mildew problems.
Papa Bob
Husky 16K hitch, Tekonsha P3,
