Banks Electronic Exhaust Brake
Trixie47
Wanting to install a Banks electroncic exhaust brake on our 2008 durmax diesel 3500 Chevy. We are having a hard time finding anyone in or around the Orlando, FL area....Anyone on here have any suggestions as to where we might find someone capable of this installation ?
2008 Chevrolet Silverado Crew Cab DW
2012 Keystone Avalanche...4 Slides
11 REPLIES 11
Devocamper
Roger10378 wrote:
Anyone should be able to do the install. It is a matter of routing a couple of wiring harnesses and plugging them in. The hardest part is getting to the plug on the transmission.
Itโ€™s not that hard to install at all . I installed the banks speedbrake on my 2007 Chevy D\A myself but that said look out for your transmission to start leaking transmission fluid at the connector after the banks harness is installed , the internal side of that connector leaks around the pins and the internal harness has to be replaced to stop the leak , not a huge job but you do have to drop the pan to replace the harness if the pins start leaking after they are disturbed. In my research at the time I learned that it was very common for the fluid to leak past the pins after pulling the connector and reinstalling the banks harness. once the internal harness was replaced the leak stoped and the banks brake worked great for towing a 16k fifth wheel however depending on the settings you use the brake can be very aggressive ,
Mike
08 NU-WA Hitchhiker Discover America 339 RSB Sold
18 Host Mammoth
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A Sold
18 Ram 3500 SLT Crew Cab DRW 4x2 6.4 4.10's
deltabravo
larry barnhart wrote:
. Hope to in a few days to be on the road to wa st and will do the cabbage patch hill ....
LOL, Cabbage Patch is the doll.
That hill (Deadman's Pass, between Pendleton and LaGrande, OR) is also called Cabbage Hill.
Cummins12V98
Sounds like things are looking up!!! Very happy for you two.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Me_Again
On our combined weight of 22920 lbs our 05 does a great job holding back on the downhills. Hope to in a few days to be on the road to wa st and will do the cabbage patch hill for the last time. Never had any issues being under control on any hill. I like simple and I have that. chevman PS might get my wife back tomorrow maybe.
Sent you a PM. Chris
larry_barnhart
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Terryallan
Try your local truck repair center.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Roger10378
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Grit_dog
Navigator
Navigator
Any diesel shop or auto repair place can do it and so can you if you can plug in a plug.
I haven't been in a truck with one, but the backpressure profiles stock don't provide a lot of braking comparetively. Seems like a great addition.
Power, fuel mileage and exhaust brake are the 3 main reasons to have a diesel, in that order IMO.
JIMNLIN
Instead of the Banks plug in system many GM owners go with a EFI live tune.
As KD54 says the Banks speed brake isn't a actual exhaust brake but just a plug in that changes the VVT vanes for more aggressive braking and different signals to the Allison tranny.
I'm not up on EFI live tuning for the Dmax in that area. I'm sure a GM owner may have more/better help.
Also check out some of the chevy/GMC diesel websites for a EFI live tune on your year model.
Cummins12V98
Banks should be able to direct you.
KD4UPL
Isn't that the one that just plugs into the OBDII port and electronically changes the vane angle in the turbo? If so I would think it's just "plug and play" as they say.
