โNov-27-2018 05:26 AM
โNov-29-2018 06:35 PM
Learjet wrote:ktmrfs wrote:philh wrote:Camreal wrote:
My 2005 discharges the batteries 24 hours a day. I have read that this is normal draw from the electrical systems. If I let the truck sit idle for a couple months I know to put a charger to keep them up. Batteries dont like being discharged.
Thanks to all the computers ๐
well, I disagree. at least 15 years ago mfg solved the long term accy discharge problem with a several stage shutdown of onboard elecronics.
if they are discharging in less than a few months something is likely amis.
Every vehicle I've had with computers and electronics in it has 3 stages of current draw after shutdown
1) immedidately after turning off ignition with everything off may be in the 1A range
2) exiting and closing doors etc. next stage of shutdown draw goes to the 100-300 ma range
3) after a set time often around 20 minutes full shutdown where current draw is close to battery self discharge rate. takes months to discharge even to 50% SOC
in the full shutdown, things like alarm etc. still are operational but don't wake up until something triggers them.
Now if something is preventing (3) from occuring or there is a fault, and you stay is (2) battery will be discharged way to soon if left unattended.
My truck has Uconnect, which uses a cellular connection to remote start, lock doors and other feature from a phone/computer...your above statement is not correct the cellular radio transmits and receives on a regular basis. Also, passive entry systems use power in standby mode. I think you quoted some old info.
โNov-29-2018 01:24 PM
โNov-29-2018 09:37 AM
โNov-29-2018 08:33 AM
โNov-29-2018 06:59 AM
โNov-29-2018 06:41 AM
โNov-29-2018 06:03 AM
IdaD wrote:
I wanted to solicit a few opinions on batteries. My 2015 Ram is on it's original set of batteries....a couple of times after running the grid heater on cold mornings the last week or two I've had a click before I turn the key back off and then it has fired up on the second try....Am I at the point I need to replace the batteries?
โNov-28-2018 05:03 PM
โNov-28-2018 08:03 AM
FLY 4 FUN wrote:ScottG wrote:Larry-D wrote:
2015 3500 CTD with 52k miles no problem with the batteries, so far. Probably just jinxed it.
Mine acted very strange when the batteries were older. When cold, I would get a rythmic discharge cycling on my V meter about 5 times as fast as the grid heaters. You could see the lights dim and brighten very quickly (it was NOT the GH's). It didn't seem to hurt anything but I eventually replaced the batts and the symptom quit immediately.
I also noted this exact same symptom on my 12, but when I read my manual it states that its normal after startup for headlights to dim and voltmeter spikes as truck warms up first minute or two.
Daryll
โNov-28-2018 06:44 AM
Cummins12V98 wrote:
My Son just replaced his on his 2015 with 88k, we ordered our trucks at the same time mine are fine.
He said there was a bit of corrosion that was not visible before removing terminals.
โNov-28-2018 03:58 AM
โNov-27-2018 06:19 PM
โNov-27-2018 06:09 PM
rhagfo wrote:
The important thing that IdaD stated in his original post was replacing BATTERIES (Plural)! This is one time a diesel cost more in maintenance than a gasser.
โNov-27-2018 05:33 PM
โNov-27-2018 03:45 PM
