Apr-04-2017 05:38 PM
Jun-21-2017 05:38 AM
Jun-21-2017 05:20 AM
bkenobi wrote:
Not saying it's high quality, but I have this one that I've used a couple times.
https://m.harborfreight.com/clamp-on-digital-multimeter-95683.html
Jun-21-2017 04:14 AM
Jun-20-2017 04:34 PM
Jun-20-2017 12:43 PM
woodhog wrote:
You need a clamp on amp meter, just clamp it around the battery wire
to see if you have a parasitic load drawing current from the batteries.
These can be bought for about $30.00 and work quite well , zero before measurement.
Current Measurement in wiring...
To understand anything in your camper's electrical system you have to
be able to measure voltage and current.
Very easy to do.
The old way is to go out after dark, disconnect the battery lead, scrape it on the terminal and look for a spark, not recommended in area of charging batteries!
Jun-20-2017 08:32 AM
Jun-20-2017 08:31 AM
Jun-20-2017 07:19 AM
bkenobi wrote:I'm a little late to this party and this is slightly off topic but I found THIS to be a very useful tool. I have used mine to monitor my battery voltage while connected to a charge timer, fridge temp, temperature swings in the house, attic temps, etc. I'm currently using it to monitor the humidity in a storage shed.
I had 2 ideas to track voltage and was curious if others had a different approach.
1) I could buy a cheap 0-99vdv digital meter off ebay and mount it in a cabinet to see what the current charge was.
2) I could use a microcontroller (eg, arduino) to read voyage and track it over time to see if it holds correctly.
I could actually do both pretty easily. Has anyone else done either and found it useful?
Jun-20-2017 07:07 AM
Jun-20-2017 06:22 AM
Jun-20-2017 06:18 AM
bkenobi wrote:
When I tried to load it yesterday, the batteries were dead (9.45v). Is this expected?
Jun-20-2017 06:17 AM
Jun-20-2017 05:57 AM
May-11-2017 12:09 PM
