โApr-29-2017 12:14 PM
โMay-28-2018 12:45 PM
โApr-30-2017 09:03 PM
โApr-30-2017 01:47 PM
โApr-30-2017 12:09 PM
โApr-30-2017 11:43 AM
โApr-30-2017 08:43 AM
โApr-30-2017 05:05 AM
facory wrote:
The power panel has the positive battery lead on one side and the negative battery lead on the opposite side. The voltage reading there is only 2.3 volts.
โApr-29-2017 06:49 PM
โApr-29-2017 04:17 PM
facory wrote:There is no diode in the circuit. Just copper, a fuse, switch and multiple connections that will conduct same in either direction.
Battery voltage without park power is 13.0 - 13.3 volts. Voltage when plugged into park power 14.4 volts. The power panel has the positive battery lead on one side and the negative battery lead on the opposite side. The voltage reading there is only 2.3 volts. If the converter is charging the batteries through those same cables then I don't understand why the battery's voltage is not coming back through. My dilemma.
โApr-29-2017 03:35 PM
โApr-29-2017 02:58 PM
โApr-29-2017 02:49 PM
facory wrote:
Battery voltage without park power is 13.0 - 13.3 volts. Voltage when plugged into park power 14.4 volts. So I know it's being sent from the converter to the battery. However, incoming voltage at the converter measure 2.3 volts.
โApr-29-2017 02:15 PM
โApr-29-2017 01:50 PM
