Battery
jimw606
I am looking into buying a used TT.
The battery was stolen from the unit.
I need to tow it 125 miles home if I buy it.
Do I need a battery hooked up on the trailer.
I am new to towing a TT.
It is a R-Vision Trail-lite Crossover 19' and weighs less than 3,000#
Thanks to all who respond. Jim
6 REPLIES 6
EldIr
If it really is less than 3000lbs, you don't need brakes. Unless the weight of the trailer exceeds 40% of the weight of the tow vehicle. It's also 3000lbs in my state and I have an enclosed snowmobile trailer with a gvwr of 2990. Imagine why they picked that number?
'01 Burb 2500 4x4 496/4.10 (3.73 effective w/ new tires)
'94 Jayco 300BH
skipnchar
Each state has outs own laws concerning maximum weights that can be towed without brakes. Check your states requirements to know if it's against the law but doubt if any states would allow that much without brakes.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
jimw606
Thanks everyone. Jim
pianotuna
Nomad II
Nomad II
Hi,
Just buy the battery you wish to use and install it when you reach the trailer.
Regards, Don
MFL
Nomad II
Nomad II
Roy is correct; everything will work off from your 7-pin, from your truck. You are required to use available break away.
You will have to decide, if you want to tow home without the breakaway being operational.
Jerry
RoyB
YES - if it has installed Electric brakes. The battery on the TT supplies power to the electric brakes in case of trailer break away when being towed. Required by DOT...
Any 12VDC battery will work for this to get you home. Even a Sears riding mower battery..
All of the 12VDC power for the trailer safety lights including electric brakes will be provided by your truck 7-way connection.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
