Mar-20-2018 06:00 AM
Apr-05-2018 01:14 PM
Mar-22-2018 12:32 PM
TKW wrote:TurnThePage wrote:
Just to add to the confusion, the newer CPAPs are no longer 12v as far as I know. I did a test run on one last year, it was 24v. I inquired. They said they were all going that way.
I have been using CPAP for years. Yes, the newer ones are 24V but you can always buy a 12V DC power supply from the manufacturer. In the old days, it's just a cigarette lighter cord to plug in the machine. The newer ones comes with a brick (believe it's a small inverter) with a 12V plug at the input end. It also provides a cable with two battery clamps for hooking up to a 12V car battery directly.
I know how it is sleeping on the wrong side of the bed. It just doesn't feel right. My one & only 12V outlet in my TT is at the bedroom ceiling at the wrong side of the bed. When boondocking, I have to switch side with DW so that the power cord doesn't dangle across the bedroom. Adding a 12V outlet to my side of bed is slowly floating to the top of "TO Do LIST" and I have one on order arriving next week. I am all thumbs when it comes to electrical stuff. Wish me luck!
Mar-22-2018 12:23 PM
Mar-22-2018 07:22 AM
darleyhavidson wrote:DownTheAvenue wrote:
Not sure why this is so difficult. Why can't you just plug an extension cord into the outlet at her side of the bed and run it under the mattress to your side of the bed?
The bed is located in the slide out. The slide out covers the outlet on her side when closed. So to prevent any accidents/damage. I am not running a cord under the mattress and plugging it into the outlet. I am not going to risk someone closing the slide with the cord in the way.
Thanks for your feedback.
Mar-22-2018 07:10 AM
Mar-21-2018 06:59 PM
Mar-21-2018 05:13 PM
darleyhavidson wrote:westend wrote:
Where is the receptacle on your wife's side of the bed located? Is it in a wall or on the bed frame?
It is on the wall. On the non-slide out wall section.
Mar-20-2018 10:15 PM
Mar-20-2018 06:42 PM
Mar-20-2018 06:31 PM
Mar-20-2018 06:00 PM
Mar-20-2018 05:56 PM
IAMICHABOD wrote:
I use One like this to make a long run to where I need it.
Mar-20-2018 05:53 PM
Mar-20-2018 05:32 PM
