โDec-07-2018 06:51 AM
โDec-08-2018 08:56 PM
โDec-08-2018 06:12 PM
โDec-08-2018 04:53 AM
โDec-08-2018 02:35 AM
โDec-07-2018 04:00 PM
dvitale300 wrote:
Hi,
On the road boon docking right now. Emptied black tank before leaving. Indicator is working correctly, but there appears to be a large clump of paper visible when you look down into the toilet. Since we're on the road - is there anything I can do? Would pouring some boiling water into the toilet help? We're inside of an even and don't have dumpling facilities. Thanks
โDec-07-2018 03:20 PM
rrupert wrote:
Perhaps the cause of your paper pyramid is from not allowing the tank to fill to sufficient depth before dumping. As said above, lots of water is good. Maybe a change in the type of TP should be considered as well.
โDec-07-2018 03:12 PM
โDec-07-2018 03:09 PM
โDec-07-2018 01:31 PM
โDec-07-2018 10:04 AM
badsix wrote:jerryjay11 wrote:
Do like I had to do and use an old broom handle and knock it down, slosh it away from the poop hole.
do this ^^^ then keep using it until your ready to leave. then fill with water and head to the nearest dump station and dump.
Jay D.
โDec-07-2018 09:58 AM
โDec-07-2018 09:52 AM
dvitale300 wrote:
Hi,
โDec-07-2018 09:42 AM
Amateur Radio K3EXU
โDec-07-2018 09:33 AM
