Jun-12-2014 10:31 AM
Jun-12-2014 05:59 PM
Jun-12-2014 05:15 PM
Jun-12-2014 05:10 PM
Jun-12-2014 04:29 PM
Jun-12-2014 01:56 PM
Jun-12-2014 12:28 PM
Jun-12-2014 12:09 PM
ScottG wrote:No battery - this is a small - 18 inch I believe, slide out. The first picture is showing the front of the slide out and is a close up of the issue. I can take a picture farther out if helpful. The second picture is the wall of the slide out. I should have tested it with a magnet before posting, but if anyrhing, it would be made of aluminum. Aluminum corrodes into aluminum oxide which is powdery white in color, but it does not rust like ferrous metal.
Is there a battery anywhere near there?
It looks like acid has gotten on it.
Jun-12-2014 11:18 AM
Jun-12-2014 11:09 AM
Jun-12-2014 11:06 AM
Jun-12-2014 10:50 AM
donn0128 wrote:As I stated, I don't think the side panel in the second picture is made of metal. Will check with a magnet - aluminum would not rust like that, and there is no evidence of water underneath the slide, or inside the slide. Besides, it has been sealed as in not extended for months. Gaskets are well maintained by me.
You have a serious water leak that has rusted out the side wall from the inside.
Jun-12-2014 10:43 AM
