Brake Upgrade 2012 F250
travisgsf
I want to upgrade my brakes for better stopping power and better feel. Any thoughts as to what's the best route? I'm willing to change whatever I need to not just the pads. Thanks
Travis - Houma, LA
2012 Ford F-250 6.7 Diesel Crew Cab FX4
Firestone Riderite Airbags
2013 Open Range RF367BHS
18K Pullrite Superglide
53 REPLIES 53
shepstone
The Super Duty went to larger brakes in 2013 maybe the parts are interchangeable?
2017 F350 Ruby Red Super Cab Dually 6.7 3.55 gears. B&W Companion 25K. BackRack. Gatorback mud guards. AUX65FCBRG aux tank. 2021 GD 380fl
2010 GMC Savanna 3500 extended 6.0
jfritz_drfritz
Suggest that you read thru this thread lots of good info here
http://www.thedieselstop.com/forums/f122/brake-pedal-soft-spongy-299471/
travisgsf
RWDIII wrote:
nohurry wrote:
When I went from an F150 to my F250, the brakes are one of the things I was most pleased with. Granted I'm not pulling the weight you are, but mine work very well, solo or towing. Good luck
That's the first thing DW and I noticed when we went from F150 to new F250,that the brakes where so much better
I agree but I feel like I've lost all that
Travis - Houma, LA
RWDIII
OLD 2006 F150 4wd 7200gvw,Lt275-65-18,Scan Guage,Garmin,flowmaster,load levelers,Firestone work rites Bronco 800
NEW 2015 F250 Scab 4wd 10000 gvw, 6.2 Scan guage,Garmin,work rites,3200 lb load,1800lb Palomino Backpack SS1200
coolbreeze01
Link to one solution: http://www.8-lug.com/tech/1405_ssbc_upgraded_brakes_for_your_lifted_ford_f_250_super_duty_install/
2014 Sandsport 26FBSL
All_I_could_aff
If brake pedal "feel" is the main issue, consider looking into a set of performance/ heavy duty flex hoses and then a fluid flush. Some trucks had considerable amount of swell on the lines under pressure which gives a mushy pedal. GM trucks from 10 or so years ago were particularly prone to this
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollinโ€™ on 33โ€™s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
ib516
Get some good quality slotted rotors and a good set of pads.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
travisgsf
Yes always use my trailer brakes and exhaust brake. I feel as if it's I've lost all the brake feel when not towing but I think it's from all the towing use.
Travis - Houma, LA
coolbreeze01
Do you use your exhaust brake?
nohurry
I'll throw in another vote for upgrading the brakes on the fiver. Yes, do change fluid, and bleed the truck's brakes, but a trailer should for the most part be stopping itself. As was alluded to in an earlier post, changing to high performance rotors, calipers, pads etc brings with it cooling challenges. Not a good thing when towing down a mountain pass!
Carl
2007 National RV, Sea Breeze
time2roll
carringb
Golden_HVAC wrote:
Hi,
I would start by changing out the brake fluid, and get the Ford 24,000 GVWR motorhome brake fluid, it has the very highest 'wet' boiling point of any brake fluid.
This is good stuff. It used to be labelled "Super-DOT-3" but has been relabeled DOT 5.1
2014 ORV really big trailer
2015 Ford Focus ST
Golden_HVAC
Hi,
IF the brakes feel 'mushy' it can be that there is to much moisture in the brake fluid, and it sometimes boils a little bit, and steam is compressible, not brake fluid. So once the moisture boils inside the brake fluid, then it becomes steam that is compressible. New brake fluid solves this problem.
With 30,000 miles on the truck, it might be time for new and thicker brake pads. They are not that expensive (less than a tank of fuel cost - say less than $75 per axle) if you or a buddy can change them in your driveway.
You can check with Napa auto parts, and they might have a stronger brake pad. However the 'stronger' brake pads are likely to warm the rotors more, and wear away more rotor material between brake pad changes. So it is a trade off. Ford designed the brake pads, and probably spent $1,000,000 testing various brake pad materials, checking them out on the race track and Arizona test track. Hot braking tests, and at 45,000 miles measuring the rotors to see how much wear is on them.
Why change the well engineered Ford product? It is not like the Ford brake pads are a known problem. Stronger than stock parts will wear out the rotors quicker.
Good luck!
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
Rich1961
Bedlam wrote:
FYI: The F350 DRW and chassis cab DRW use larger brakes, but none use tires taller than 33".
I should have been more clear, the Chassis Cab I drive is an F350 SRW.
2016 Chevrolet/Duramax 3500HD Dually Crew Cab B&W RVK 3700 5th Wheel Hitch
2014 Arctic Fox 29-5T
rhagfo
travisgsf wrote:
I am running slightly larger tires on the 5th wheel. BFG Commercial TA. Also running an inch larger on my truck. 35" tires. Only reason I assumed upgrade the trucks brakes is when not towing my truck brakes feel really mushy. I only have 30k miles on the truck
Sounds like you need a a good break bleeding!!
