Dec-03-2015 12:50 PM
Jan-11-2016 10:36 AM
Gdetrailer wrote:
I bought NEITHER of my trailers new, and NEITHER of the sellers ever "disclosed" all the bad points and non working things..It was used and cheap so I UNDERSTOOD that I would have to fix things.
Jan-11-2016 10:32 AM
Jan-11-2016 10:16 AM
Jan-10-2016 02:37 PM
tomkaren13 wrote:
Sold it to a man who will be setting it up and using it as a home base. he travels for work. He knows the brakes do not work.
Jan-10-2016 12:16 PM
Jan-10-2016 10:07 AM
Dec-05-2015 11:41 AM
Dec-05-2015 10:39 AM
Lantley wrote:
I guess the real question is how can anyone no what it's gonna cost via the internet? We have no idea what is wrong. Could be simple adjustment. Broken wire, bad connection. Problem with controller. Or the brakes may need a total rebuild.
Puts you in the $75.00-$600.00 range. How's that for an uneducated guess?
I suggest taking it in for an estimate and then decide how much you are willing to spend/invest.
If the trailer is in decent shape otherwise I would not let a brake job be the deal breaker.
Dec-05-2015 09:31 AM
Dec-05-2015 09:24 AM
Dec-05-2015 09:14 AM
Dec-05-2015 08:55 AM
tomkaren13 wrote:
When TT is hooked up and brakes applied a buzzing sound is heard but no brakes are working. We pulled the break-a-way switch and no brakes. Got an estimate for diagnostics of $50 applied to work if done.
Would like some more input from here as to what we may expect.
Dec-05-2015 07:53 AM
westend wrote:Gdetrailer wrote:Possibly but they also stated this:temccarthy1 wrote:Lynnmor wrote:
The trailer is a dozen years old, so just pull the drums and have a look. It is way overdue for a brake inspection. You may find grease, rust, worn shoes, broken hardware or bad wiring. The bearings need to be inspected and repacked with grease and properly adjusted. All the advice people can give you from afar will not give you a trailer that is safe.
AMEN to that!
Gee whizz folks.. Get a grip..
The OP POSTED THIS..
"When TT is hooked up and brakes applied a buzzing sound is heard but no brakes are working. We pulled the break-a-way switch and no brakes. Got an estimate for diagnostics of $50 applied to work if done.
Would like some more input from here as to what we may expect."
SOOOO I don't think the OP was planning to use or sell the trailer "as is"..
I suspect they are FULLY INTENTIONALLY WANTING TO GET THE BRAKES WORKING. They are just asking what they could possible expect to pay and/or what parts may be needed.Any idea of what the cost would be to have them fixed. Do not want to spend alot on this well used TT.
To me that indicates the repair cost may exceed their comfortability level. Besides, if they the brakes absolutely need service, why ask, if the work is going to be done regardless.
Dec-04-2015 07:20 PM
AMEN to that!
