โJun-06-2014 06:04 PM
โJul-08-2014 06:40 AM
โJun-12-2014 11:49 AM
Gebrown wrote:
No one is giving you a hard time for looking at trailers 34' in length???
โJun-09-2014 05:11 AM
โJun-08-2014 07:42 PM
โJun-08-2014 06:48 PM
โJun-08-2014 09:27 AM
myredracer wrote:
At the last couple of RV shows here, I've noticed that the Whitehawks have had the BAL/Norco Ultraframe. I have in the past also seen the 3-piece, welded up, I-beam made from separate pieces of sheet steel also used. I am not sure if Jayco has switched over to the Ultraframe on some or all models, but if the other two have the fabricated I-beam, I would most assuredly go with the Ultraframe as it is much stronger and more durable.
โJun-07-2014 12:12 PM
โJun-06-2014 08:17 PM
โJun-06-2014 06:20 PM
Rvinnewbury wrote:
We have Bullet Premier 31BHPR and really enjoy it. The back bunk in nice and large a very functional. We moved the tv from the outside to the bunk area so the kids can hook up their xbox, which is a life saver on those raining day trips. We also pull it with a silverado 1500 it is enough truck. One feature I like is the pantry in the kitchen, a lot of trailers with similar floorplans don't have that. Anyways, hope this helps.
โJun-06-2014 06:14 PM
