Feb-09-2019 05:27 PM
Feb-13-2019 09:37 AM
Feb-13-2019 09:15 AM
Feb-13-2019 07:49 AM
CaLBaR wrote:yillb wrote:
I'm sorry you have to deal with all the people who can't do basic math. If the trailer is within the limitations that your truck is capable of, then so be it.
I noticed a couple of people were saying don't pay attention to the dry weight.... ffs, sorry for them too. The dry weight of the trailer is the most important weight you can look at. This is how you get an idea of how much the trailer weighs before you add propane, water, goods, etc. Since it has a GVWR the logic is you must know the exact weight of everything going into the trailer. Take your try weight, and add all that additional weight you added to the dry weight. Then you have your weight. Why anyone would tell you dry weight is basically useless, just can't do basic math. Now, your truck, with a 10K towing capacity. IF your trailer weighs 8k dry, let's just ASSUME you manage to add 1000 pounds worth of ****, so it gets up to 9k, you're still within your limits. That will put you at around 800 - 1000 pounds in tongue weight. You didn't mention your payload ( or at least I did not see it ), if you have an extra 1000 pounds of payload on a ram, kudos to you. The only thing i see here is " not doable " is going to be your payload, and that's even debatable, I don't know what your payload is, though I'm assuming it's somehwere around 1600 / 1800. After adding in kids / animals / wive(s), what's left?. Everything else is within your limitations. you have a long trailer, and that ram has a short wheelbase compared to other full 1 ton trucks. However, they don't sell trucks and say " Gotta keep the length below X ". Have fun!
I couldn't agree more. Well said. That is how I decided that my current trailer will be OK for my truck. I knew how much stuff I put into my old trailer so knew I would be close but within my tow ratings. Used that plus battery, propane weights to estimate tongue weight loaded. Not perfect but I was close enough once I weighed the combo to my estimate that it worked out well.
Feb-13-2019 05:36 AM
MarkRBD2019 wrote:
Folks, just so you will know, I appreciate each and every comment you have made and based on your more experienced views I am rethinking my plan for a TT and considering a 28' to 30' box instead and a rental tryout.
I dont know anything about renting a TT, any advice on that? Think based on the comments that have been posted, I better have some insurance on the rental when if I get one. LOL
Feb-13-2019 05:34 AM
Ride S40T wrote:CaLBaR wrote:Ride S40T wrote:
You're going to hear varying degrees of good advice on RV forums and A LOT of solid recommendations based on years of experience.
After considering any or everything read here, please please go out to one of the reputable sites like Shereline and run all the TV and TT specs. Find a worksheet that uses all the specs all the way down to the wheelbase, do not use a simple "pulling capacity" worksheet produced by TV manufacturers.
Can you supply the links or the websites that you are referencing that take wheelbase and other information into account. I did a search and could not find one and it would be great if people on the forum could look that up for some additional information when trying to decide on TV/trailer combinations.
Thanks,
Just a few tow capacity Links. Google, be our friend.
Feb-12-2019 04:34 PM
Feb-12-2019 04:27 PM
Feb-12-2019 03:47 PM
donn0128 wrote:
Good luck attempting to tow that monster. Even with a 3500 36 feet behind it would not be a good fit.
Feb-11-2019 08:37 PM
Feb-11-2019 08:14 PM
Feb-11-2019 07:40 PM
Feb-11-2019 07:35 PM
"Can" you haul something that big behind a 1500 (any make)? Sure. Will it be unsafe or kill the truck? Possibly. Run the numbers, even those wheelbase specs are important. Let the science behind towing be your first guide. Then decide on a TT within those parameters.
Lastly, please know dry weight & tongue weight issued by TT mfgrs can be a little optimistic on the low side. We used a tongue scale to find out our hitch weight is about 100lbs more than advertised.
Thanks,
Feb-11-2019 08:29 AM
Feb-10-2019 01:37 PM
MarkRBD2019 wrote:
Thanks I appreciate all the comments, keep them coming. I need to check the payload of my Ram but it sounds like this idea is going down like the Titanic. Sounds like I need a lot less TT or a lot more truck.
