Camper Door Windows dual pane???
ggadwa
I know winter is over but I am always looking for ways to improve TC camping pleasure and convenience....
I have never seen a camper with insulated entrance door windows...these two windows are huge source of condensation and associated cold air interface to the great cold outdoors. We use insulated curtains over the door windows for winter camping but.....
Has anyone found a source for Thermal Pane or similar window inserts for Truck Camper entry door windows?
Gary & Laurii
HAM RADIO Operator since 1964 'W7FSI'
EAGLE CAP 2011 950 CUSTOM BUILT by the great folks at LaGrande Oregon
2012 FORD 350 XLT 6.7L Diesel 4x4 Super Cab with lots of stuff
15 REPLIES 15
pjay9
AnEV942...to solve the issue of massive H2O on front cab over window, I made an insulated flexible planel that worked well for many years. this is modified from my original install. Use 1/2" bed roll foam from a sports store covered with bubble foil both sides (get at HD), covered again with heavy color coordinated cloth (sort of like thin blanket material) and padded with that white fluffy stuff used in furniture cushions available at the fabric store...used industrial spray on contact cement to assemble it all. It was of such a size and stiff/flexibe, use snaps or velcro to hold in place. It never got really wet, never mildewed, stopped alot of heat (sun bake black glass) and cold down my neck was gone too. Good weekend project after you collect all the materials. Fabric didn't come wide enuf to do it economically so I used contrasting color ultrasuade on ends for about 12"... gave it depth and looked like it belonged, since I had covered the new dense foam dinette seat cushions in the same fabric...tied it all together...I'll try to find some pics.
2005 Lance 1161, 2004 Dodge CTD 3500 Dually 19.5's Stabiloads Roadmaster Sway, 2009 20' Raider 185 Pro Fish 90hp & 9.9 Yamaha vintage Penn elec.downriggers EZLoad roller trailer
AnEv942
There are many companies that make RV/marine windows, single/dual pane, fixed/slider in about any configuration you need. ie, dont know anything about them but just one,http://www.rvwindows.com/products/rv-elite-dual-pane-windows-series-1800/.
Likly also be ordered thru most RV mfgs, in PJs case as rebuilding camper, replacement shoudnt be hard to find-they are not cheap.
Which some have retro'd their own quasi dual pane rear door window.
KKELLER14K for one, its in the TCU thread/exterior section. If I had a problem with our door windows I'd try that, but we dont. I assume the simple door seal/door construction leaks enough air or cold enough to keep fairly dry as its the window that has least condensation.
On the round to it is our cabover window, its the worst 'water generator'. There is a flat flange that I will seal a piece of plexi to, think it'd help. I had the opportunity couple of winters ago, because there is an actual secondary flange that would accept a second window, I always thought if/when removed id make semi dual. However it was when we used to get rain so I didnt spend the time needed. Ive not seen any long term results if these attempts help.
If though I was to spend couple of hundred (not) Id opt for the Edwin opening window, velcro some foil bubble ins. for winter use.
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
http://www.ourelkhorn.itgo.com
towpro
I ordered storm windows for my Wolf Creek (which I pick up Saturday). And I think I understand they do not come for the back door.
but what about that stuff you put on home windows that is clear, it applies with double sided tape and you shrink it with a hair dryer? that would work on a pickup camper as well.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
pjay9
ggadwa wrote:
Our camper has dual pane windows throughout except for the door windows that sweat condensation severely during our many winter TC camping adventures....I just e-mailed Atwood Mobile to see if they make any window inserts besides what is obvious on their web site.
Gary
I have not seen dual pane wondows in TC's...would you take some pics on how it works, PLS!! Close up of how installed and what is covered, if you can.
Can you open your windows, slide or cranck out? Maybe someone has a site that shows how all this works.
I was thiking of the plexi and silicon method (mention here)to cover the stationary parts...it would help some...In my rebuild I have eliminated the cab pass thru and aft window, so that will help plus the galley window is being downsized, actually using the pass thru in place of galley, and the forward cab over window is gone...so this will help with the temp. I am replacing the aft and pass thru with marine style fixed round ports, just for security purpose and they will be double pane as I am installing a pair back to back, inside and outside. But the big window in the slide has loads of glass. I will be interested in the comments and ideas. THX.
dadwolf2
RinconVTR wrote:
These sort of things equate to added weight and cost, especially dual pane glass widows. Its likely that in regards to TT's, there is not much to gain from adding dual pane windows and thicker walls for increased R value. The return just isn't there.
Dual pane is pretty common in the windows but for some reason not the back door window. I have them in my camper (except back door).
2005 Dodge Ram 2500 CTD,4X4,NV5600
2014 Adventurer 86FB
samuraiowner
I wonder if some plexiglass and velcro cut to fit would work? be less cost.
Samuraiowner
ggadwa
Gary
RinconVTR
larrybluhm
There are two panes of glass in the EDWIN replacement window to allow the the window to be opened. It is not a dual pane insulated window.
2011 Northstar LaredoSC, solar/'04 Dodge 2500, Cummins.
IAMICHABOD
Good deal,let us know how it turns out.
Gary
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
ggadwa
IAMICABOD,
I promptly e-mailed Atwood Mobile to see what they have. Thanks for the tip we'll see what comes of it.
Gary
joeshmoe
Super_Dave wrote:
joeshmoe wrote:
I've wondered that myself. Heck, even the seal around the door doesn't do much to keep the cold out. Maybe a company makes (or could make) fully insulated, aftermarket door for campers with mediocre insulation properties.
It would be kind of neat to swap the screen door out for a storm door.
Interesting. Storm door to go with storm windows.
2014 Northwood Wolf Creek 850
2005 Ford F350 SRW SuperCab/LongBed 6.0 Powerstroke
QuickTrick's Towing Tune
Torklift Tie Downs/Fastguns/Upper/Lower Stableloads
Rancho 9000's
Super_Dave
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
IAMICHABOD
I replaced my door glass with an EDWIN and as I recall they make one with duel pane glass. You might give them a call. This is who I talked to and she was very helpful.
Sue Phillips
Atwood Mobile Products
Replacement window line
574-266-4829
Cell # 260-350-2414
fax 574-262-9469
e-mail s.phillips@atwoodmobile.com
Normal Business Hours 6:00-2:30
