Can my TV handle this 5th Wheel?
zackyboy3rs
This is the one I want. Before you decide please realize that we travel with ONLY 10 gallons of water (max) & use it to flush toilet when we stop.
Tv - 6000 lbs wt. / 3250 payload/ 10000 towing max./ 16000 GVWR
5th wheel specs - 7547 dry/ 1035 hitch/ 10800 gvrw
That means I could add about 3200 lbs of water, cloths, food...etc.? Correct
I mainly camp in eastern NC but MIGHT travel to mountains 1 a year. Fancy Gap, VA & Black mountain, N C are the biggest obstacles.
Can my TW handle it? If so, what hitch would you recommend?
Thanks!
2009 Chevy Silverado LTZ 2500HD 6.0L, 3.73, Gas sipper
2015 Jayco Eagle HT 27.5 RLTS
22 REPLIES 22
BenK
Suspect your numbers and the best thing to do is to go out and actually
weigh your truck, axle by axle, both fully loaded ready to go and empty
Comments in red embedded below
Suspect the 6,000 is the published 'curb' for your 2500HD. 'Curb' is
the 'stripper' model and no options...like the Duramax/Allison which
will add several hundred pounds, min, to that curb of 6K. Even with
the small block 6L, it will weigh more than the 'curb', if you have
any options like: AC, power door/window/seat, upgrade interior, etc, etc
Suspect the 16,000 is the GCWR (gross combined weight rating)...
Note that if you have over sized (larger dia) tires...that 3.73 is
effectively changed to a lower numeric, which lessens the tow
ratings.
Payload is typically based on a 'curb' weight, so it will be less
by the weight of all the options
The 'dry' is the 'curb' for the TV. No options and suspect you already
knew that with your comment of limiting your water
Only if you do have a 'curb' weight truck...again, best to go out
and actually weigh your truck, axle by axle.
That is the only way to know where you are in reference to your trucks
ratings
That 'might' becomes a reality all too often and I refer to those instances
as "when Mr Murphy crosses your path"
If you are only looking for a confirmation, then you will get tons of
them and note that there is only one person responsible for the setup
and that is the driver. Maybe not even you, the OP, but someone else
driving it
I do not normally say yes or no, but provide the information to
figure it out yourself, as again, there is only person responsible
for the setup..the driver
Thanks!
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
APT
Plenty of truck and motor/gearing with the 6-spd. I prefer the 4.10 with 6th gear's 0.67:1 ratio, but the 5 usable towing gears works well.
2017 Subaru Outback 3.6R
ependydad
For the most part, off the cuff - it sounds like you'll be within your ratings with this truck and fifth wheel combination.
The biggest wildcard is how much actual payload do you have in your truck? Myself, my wife, my family, truck add-ons (bed cover, spray in liner) and hitch ate up 1,200 pounds of my yellow/white sticker'd payload.
See if this helps:
http://learntorv.blogspot.com/p/what-can-i-tow.html
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
zackyboy3rs
rhagfo wrote:
donn0128 wrote:
Enough truck? Yes. Enough motor? Right on the edge.
X2 even those 3.73's will hurt you in the hills, take it to 4.10's and you will have a better towing experience.
We do the mountains every other year or so.
zackyboy3rs
Michelle.S wrote:
OK, think you got a number mixed up tho: 16000 is probably the GCWR (max weight of TV and RV combined), because the GVWR on my Diesel Dually is only 13000. So you have a max tow of 10000 but a RV with a gross of 10800 which will put the real world pin weight close to 2000. Remember that Dry weight is usless as many RVs leave the Factory 1000 Lbs or more above that number once options are added. No matter how you look at it, you will be at or over just about every spec of your TV. Me, I wouldn't do it. Only you can make the final decision.
I would be at only if i fill the fw up to maximum capacity correct? I do not plan to
Add 3000 lbs of cargo. Probably more like 1500-1700lbs.
rhagfo
Michelle_S
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
donn0128
