โJan-04-2017 08:08 AM
โJan-05-2017 04:41 PM
โJan-05-2017 05:25 AM
โJan-05-2017 05:15 AM
โJan-04-2017 03:56 PM
โJan-04-2017 03:46 PM
โJan-04-2017 02:21 PM
TundraTower wrote:
The 5 and 11 lb containers that "Hedge" brought up is an excellent idea that I was not even aware of. I can combine these for a decent amount of LP gas at reduced weight with some back-up. What an elegant and probably more useful solution !!
I've found these tanks at Ace Hardware, Lowes, Home Depot, although have to order them.
My local propane place says they will fill them, but have you ever run into resistance at having them refilled on the road???
โJan-04-2017 11:40 AM
โJan-04-2017 11:32 AM
โJan-04-2017 09:49 AM
โJan-04-2017 09:47 AM
โJan-04-2017 09:33 AM
โJan-04-2017 08:40 AM
โJan-04-2017 08:24 AM
TundraTower wrote:
I found a fitting that will allow you to connect a 1 lb disposable propane bottle to the regulator - apparently made for BBQ grills. This might be handy for a low weight limited back-up in the summer.
Is there a technical reason you would not connect a disposable propane bottle to the RV gas system?
