Nov-10-2015 05:43 AM
Nov-11-2015 09:11 AM
Hone Eagle wrote:
Cars - (not trucks of which there are very few,)the EU will discourage diesel use going forward by increasing the tax on it.
So fewer sold and more fuel for us.
It also illustrates why North america is suddenly seeing a bunch of small diesel engines,the original market is shrinking.
Nov-11-2015 09:08 AM
Nov-11-2015 09:00 AM
RobertRyan wrote:hone eagle wrote:
France Portgal Belgum etc etc
From a year ago ,its no fantasy they are backing away from diesel cars and the VW debacle can only speed it up .
More diesel for us .
Not Diesel Pickups, all Commercial vehicles in Europe are Diesel. Although ,Diesel Pickups are exploding Globally , Gas options dying. Europeans do not buy Pickups only , Vans and Cab Chassis variants. Diesel cars used for towing a lot.
They are in Europe are coming down heavily on older Gas engines and the high particulate DFI engines used on , newer Gas engines
APT wrote:kevperro wrote:
The gasers are cheap used relative to a diesel, often more than the $8K point of entry due to demand.
That just proved your original point invalid, at least with new. If you pay $8k more new and it's worth $8k more in 5 years compared to a similarly equipped gas model, then you get all the benefits of the diesels for "free".
Nov-11-2015 08:50 AM
Nov-11-2015 08:46 AM
donn0128 wrote:
About the same as the Ram 1500 Ecodiesel huh?
Nov-11-2015 08:43 AM
Nov-11-2015 08:41 AM
FishOnOne wrote:45Ricochet wrote:
I'm not sure I would want to spend $3700 more for the diesel for a couple of MPG better mileage. The V6 gasser is pulling in a good 22 MPG combo. If I needed more pulling power I would have just bought a regular sized pickup.
So how does the GMC tow the boat?
Nov-11-2015 07:35 AM
IdaD wrote:APT wrote:
The prior two posts neglect the higher used value of vehicle with more equipment, especially the diesels. For the first 10 years or so, diesel powered HD trucks retain at least 50% of that new up front cost. We don't know what the used values will be for the GM twins baby duramax, but I expect similar 50%-ish over the next 10 years.
Anyone getting 22mpg with the 3.6L would likely get over 30mpg in a diesel. I've never gotten more than 16mpg in the crossovers and 19mpg in cars equipped with that engine. The 3.6L driving experience has never impressed me either.
Yep. The cost is a wash, at least on the big diesels (excluding the bad-year Fords). Your up front cost is higher and maintenance costs may be somewhat higher, but your fuel cost if lower and your resale is better. Overall when you think about all the money you're going to spend on that truck in terms of up front cost, fuel, tires, maintenance, brakes, shocks, etc., etc., etc., the marginal difference in cost between big gas and big diesel is immaterial. I'm not quite sure why people get so hung up on it.
Performance and driving enjoyment are far larger factors to me, and they're the reason I drive an oil burner.
Nov-11-2015 07:18 AM
Nov-11-2015 07:13 AM
Nov-11-2015 06:49 AM
Nov-11-2015 06:44 AM
Nov-11-2015 06:42 AM
Vulcanmars wrote:
A major factor often overlooked is ownership cost. $4K more to purchase (6-8 for full size trucks), 2-3 times more for routine services, def fluid, etc.
Nov-11-2015 03:19 AM
