interesting little camper.
I have a heat pump on my 5er, problem is once it hits 40f its useless. Than the temp has to drop 4 more degrees before gas comes on and brings temps backup to set temp (while heat pump continues to blow cold air). I usually wake up cold before that 4 deg drop completes and switch it over to gas heat. They sure thought that one out well, but what do you expect from RV industry.
They should be using the mini split systems by now.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
