Nov-29-2017 02:00 PM
Dec-10-2017 08:39 AM
donn0128 wrote:
Best hands down is the Weber Q series.
Dec-04-2017 08:19 PM
Dec-04-2017 07:39 PM
Dec-04-2017 12:44 PM
Dec-04-2017 11:52 AM
Dec-03-2017 09:37 AM
Dec-03-2017 08:56 AM
Dec-02-2017 09:12 AM
Fireballsocal wrote:
A few words on the weber Q line, my 10 year old baby Q in particular.
They are built to last. Mine is a bit over 10 years old, used year round here at my house, and has had no failures.
Dec-02-2017 08:13 AM
Dec-02-2017 06:44 AM
Dec-02-2017 05:10 AM
Nov-30-2017 07:38 PM
CavemanCharlie wrote:
In the first post it was asked about a "collapsible grill" This is the only one listed by members so far that I would call "collapsible". The rest of them are "portable".
Nov-30-2017 07:21 PM
SoundGuy wrote:ZeeLet50 wrote:
I have an quick connect at the back of my camper. Will the Weber work with this if i get the right connections or do i have to get a different regulator?
It'll work just fine but requires removal of the Q's regulator so you can feed your trailer's low pressure quick disconnect feed directly to the Q's low pressure burner. The gas valve is separate from the regulator so you still have control over the size of the flame. All you need is a hose with the proper size quick disconnect nipple to match your trailer's quick disconnect fitting and the correct size of threaded fitting at the other end of the hose that will screw on to the Q in place of the regulator.
Nov-30-2017 04:31 PM
rockhillmanor wrote:
When I went full time I tried them all! And threw them all out or gave them all away!! :C
THIS is what I ended up with. Fits all the needs of grilling. And more importantly takes up very little space and is FLAT top and bottom for storage in our very small RV storage bays.
The thinnest and flattest bbq grill I have found!
Takes up the space of a laptop AND the top is flat. Which means you can put stuff on top of it in storage bay. Weber Q and most of the others have rounded tops and/or handles on top.
They come in all combinations.
2 burners,
1 burner w/grill,
Full grill
.....and pancake type griddle accessory add on for all three.
They are found at big box sporting stores and are made by several different companies. camp chief ranier, texsport, stansport, coleman. Different brand names same stove.
