Apr-07-2021 04:53 PM
Apr-17-2021 04:12 PM
Apr-17-2021 03:12 PM
Apr-17-2021 03:10 PM
Z-Peller wrote:
My 2016 GMC long box is 7/16" drop at tailgate when straight edge is run from front of the box.
I need lift for my camper and use two 4'x8' 3/4" sheets of plywood. I shim those with a 1/2" x12" plywood piece across width of box at tailgate.
Apr-15-2021 06:58 AM
dhull wrote:
So I cut my mud flaps back to 15" and added a 3/16" board in front of the thick portion of it to form a wedge of sorts. So I got the 7/16" thick at the back for 8" then its 1/4" thick out to the 15".
Thanks for all the replies...
Apr-14-2021 03:17 PM
Apr-09-2021 09:57 PM
Z-Peller wrote:....Shows pic of a Canadian 2x4...... a Newfie Straight edge
Nope, not a H depot airplane propeller...this one eyeballed carefully before using and was straight...my 4 foot level was 4 feet too short for this job.:B
Apr-09-2021 06:50 PM
Apr-09-2021 01:33 PM
Apr-09-2021 08:13 AM
dhull wrote:
Didn't you trim some off the length of your mats?
Apr-09-2021 07:19 AM
Apr-09-2021 12:22 AM
Apr-08-2021 09:27 AM
MORSNOW wrote:
There is a center crown in the box around the axle area to allow water drainage front and rear, it is obvious when I ran a 4' level lengthwise in the box. I put two rubber semi mud flaps side by side in the back half under my rubber camper mat, problem solved.
Apr-08-2021 08:09 AM
Apr-08-2021 05:21 AM
