Corner tie down repair
TBob
Hi all - new to the forum and have done some searching as well as looking here for an answer
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25966285.cfm
I have a 1995 Lance 945 and need to repair the front right tie down point and was looking for any info on this repair. When I tighten the tiedown the corner trim pulls down from the aluminum siding which tells me something is in need of repair. Also there is bulging around the tiedown when a load is applied.
Thanks for your time,
Bob
5 REPLIES 5
therobzilla
TBob, I see you finally made it on the site! Welcome, it's about time....
Rob
AnEv942
click My Forums top of page under your user name, then in the navigation bar ..
Buddy List|My Preferences|My Profile|My RV Details|Private Messages |My Posts|Block Members|Hide Forums
click My Preferences,
half way down the page under general preference are some check boxes ,
one of them is Show images that are part of posts ( not recommended for dial-up users ) ensure its checked.
While your there adding your truck and camper a good idea for your signature-then when making posts folks could look to see what set up you have for a more appropriate answer/suggestion etc
Yes not seeing pictures would make it harder ๐Ÿ™‚
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
TBob
thanks for the replies.
Can anyone now tell me what setting I need to turn on to see pictures?
I get this on the treads * image not shown due to your preference setting *
Thanks,
Bob
Artum_Snowbird
Hi Bob,
I did a repair like that on a 1994 Snowbird.
While it is not the actual tie down location, but the corner, many of the methods could be the same.
First, I had jack supports that wrapped both sides of the corner, and had a tab underneath as well for vertical support. These were aftermarket fabricated, and of course were the first thing off the corner. As I pulled the various screws and lag bolts out, I realized that there was really nothing solid behind them. Layer upon layer was then peeled back, until I got into the actual frame, and I realized the 1.25 by 1.25 corner post was completely rotten from the bed extension to the bottom. I removed all that I could, and treated what was left with Git Rot to preserve and stabilize the rest.
Then I fashioned a new corner piece to fit what I had removed, and dry fit it perfectly. I then fashioned other pieces some solid, and some plywood that would extend into the various directions of the corner and upright frame and adhere to the remaining wood, and dry fit each piece with great care and precision. This essentially provided a much more solid and thick corner.
Once I was happy with the dry fit, I coated each piece with the Git Rot solution to preserve the pieces, and let them dry. From there I began the assembly and used their Git Rot Epoxy and glued and clamped each piece in place, one at a time and let the epoxy dry between pieces.
Once the corner was totally solid, I drilled it out for bolts to hold the corner bracket on, and put it all back together again, finishing up with the jack bracket glued on with Sikaflex and bolts.
Do a search for Git Rot, and you will see the products and their uses. It worked perfectly.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
AnEv942
A quick look at couple of older threads-probably similar
specifically Ralphs an 01 lance and Jefes '98
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27203635.cfm
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27553842.cfm
