โJul-28-2014 10:46 AM
โAug-01-2014 12:47 PM
GoFish wrote:
Thanks for all of your replies. I now feel even dumber than before and that was quite a hurdle.
โAug-01-2014 10:56 AM
โAug-01-2014 05:24 AM
eb145 wrote:
OP, I'm pretty sure this is exactly what you are looking for.
Ed
โJul-31-2014 08:22 PM
bcbigfoot wrote:
Here is a DC to DC battery charger/isolator that is discussed in another RV.net thread. http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27446869.cfm
โJul-31-2014 03:18 PM
โJul-31-2014 02:00 PM
โJul-31-2014 11:30 AM
DiploStrat wrote:GoFish wrote:
โฆ is there a way around this without having to rewire everything?
No, because it is the small wire, and distance to your camper, that is limiting your charge rate.
โJul-31-2014 10:51 AM
Some of these comments are just way over my comprehension level, so I don't know if my question has been answered, or not.
I should probably restate my original query. As I am now configured, I take power from the combined battery output tap and send it to a solenoid and on to the camper through a 10ga. stranded wire. It seems to me that the voltage regulator is limiting the output to the camper batteries when I am driving because it senses that the truck batteries are fully charged. I have a Trimetric battery monitor installed and output to the camper batteries with the truck running is only in the 5-8 amp range. It seems like I should be able to get more out of the alternators than that.
In simple English, is there a way around this without having to rewire everything? In my owners manual, it briefly references an option for what it calls an alternate battery and shows an image of a connection that is supposed to be located on the firewall near the rear battery in the truck engine compartment. I have briefly looked for that connector and can't find it.
โJul-31-2014 10:36 AM
โJul-31-2014 10:19 AM
โJul-31-2014 09:08 AM
โJul-30-2014 04:25 PM
โJul-30-2014 04:06 PM
DiploStrat wrote:
-- Current: Lifeline AGM batteries spec a charge amperage of up to 5C. Some others actually spec no limit. Open lead acid batteries typically want a lower charge rate.
โJul-30-2014 01:24 PM
HMS Beagle wrote:Good point. I should have said; "higher initial charge rate".
Larger than #8 wire may allow higher charge rates, but in most installations still will not make much difference in charge time as you will not see those higher charge rates for long.
GordonThree wrote:It is called a "lift gate connector".
What is the name of this connector set? It's impressive looking and looks "marine" in nature.
