Correct Truck
dixonce
I am looking to purchase a Grand Design Momentum TH 376th. The GVWR is 20,000lbs. The truck I am looking to use for this is the 2017 F350 dually with the diesel. Do have enough truck once loaded with golf cart and necessary camping essentials?
37 REPLIES 37
Me_Again
To OP, any one of the three latest generation duallies will handle the trailer you are looking at. Pick the one your DW likes the best, and you will be a happy man.
Me_Again
vonzoog wrote:
Thanks Cummins12V98,
Your response is pretty much what I was already thinking. Was hoping to hear that someone else has been there and done that. I had not thought about adding the Bilstien shocks, but sounds like a good idea.
My current toy hauler is squatting the truck about 3 inches in the rear and I am noticing my headlights are a little high. Going with the Momentum would/should squat the truck a little more. The added pin weight had me more concerned than the gearing requirements.
Would adding the Bilstiens now make a noticeable difference over the stock setup?
Thanks again,
Find one one with the Aisin tranny! Then anyone of the three ratio's will cover that load.
On edit: I see you already own the truck and made the mistake of not getting one with an Aisin tranny!!!!! For the RAM to play equally with the other two, it needs the optional Aisin tranny.
If you do more towing than running around empty get 4:10's if the other way around get 3:42's. 3:42's will tow in 5th the same as 4:10'S in 6th.
Advantage of 3:42's is a freeway cruiser bobtail! 80MPH is only 1750 RPM. ๐Ÿ™‚ ๐Ÿ™‚ ๐Ÿ™‚
vonzoog
Thanks again,
If you have to ask why I drive a Diesel, then you will never understand.
2016 Ram 3500 DRW
Cummins(370/800) 68RE Auto 3.73 Rear
2018 Momentum 376TH
Cummins12V98
The RV you mention has a GVWR of 20,000#. If fully loaded you will be pushing 30,000# combined. Most likely will not NEED bags but a set of Bilstien's and bags set to 30# with RV attached will make for an even better ride.
Your trucks GCVWR is 27,300# with 3.73's. If you had 4.10's it would increase to 30,300#. Best thing is to tow it and decide if the gears need to be changed. Not the PERFECT gearing but I see ZERO issues.
I towed a combined 29K with a 11 HO RAM with 3.42's, only issue was getting the load rolling on a grade. Towed in 5th with same rpm as 4.10 in 6th. Your 16 is physically more capable than my 11 was.
Buy the rV hook up and see what you think. I am betting you will be very happy.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
vonzoog
Question ( mostly to RAM owners, but everyone else are welcome to join in).
Looking at possibly a Momentum 376TH. Do you think my 2016 RAM DRW with a 68 RE transmission and 3.73 rears is adequate for this unit.
1st. Would I need air bags to keep everything level?
2nd. Would I need to change out rear to 4.10 gears?
Thanks in advance,
2016 Ram 3500 DRW
2018 Momentum 376TH
shammyman
I own this setup.
2016 F350 diesel dually.
2016 Grand Design 385TH tri-axle.
I have the Trailair Kingbox with inflatable tire and shock absorber (must have).
I use the Reese Elite 25K hitch mounted in my bed. I suggest you get some airbags on the dually as they made a huge positive difference for me.
I sometimes need to look in my mirrors just to remind me I'm towing!
Awesome uphill...great braking...no sway.
I am positive I was WAY overweight last summer driving from MN to MA with zero regrets and zero hassle!
blt2ski
Moderator
Moderator
Jim who!?!?!????:b:b
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
NC_Hauler
I meant to say, you know how laid back and introverted I am... but though I somehow messed it up Marty, it appears you got my drift:B
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
blt2ski
Moderator
Moderator
NC Hauler wrote:
blt2ski wrote:
FishOnOne wrote:
NC Hauler wrote:
GROUP HUG!!!
Jim
Good to see you back Jim....
Who's Jim?!?!?!?!?????
marty
I KNOW you haven't forgotten laid back, introverted me Marty;)
Jim
:b:b
NC_Hauler
blt2ski wrote:
FishOnOne wrote:
NC Hauler wrote:
GROUP HUG!!!
Jim
marty
Jim
B&W RVK3600 Hitch
blt2ski
Moderator
Moderator
FishOnOne wrote:
NC Hauler wrote:
GROUP HUG!!!
Jim
marty
NC_Hauler
FishOnOne wrote:
NC Hauler wrote:
GROUP HUG!!!
Jim
Thanks buddy:)
Jim
B&W RVK3600 Hitch
tinner12002
The 2017 F350 would be a great truck to pull your Momentum, but the best truck would be the Ram 3500!! Just kidding, your Ford will do you good...darn I had a hard time saying that...lol!
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
FishOnOne
NC Hauler wrote:
GROUP HUG!!!
Jim
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
