Feb-01-2016 08:22 AM
Feb-02-2016 10:49 AM
Feb-02-2016 09:38 AM
Feb-02-2016 07:06 AM
~DJ~ wrote:
I don't use the humidifier even at home. Never could tell the difference and much less chance of a yeast or mold infection!!
Feb-02-2016 06:53 AM
Feb-02-2016 06:31 AM
Feb-02-2016 05:07 AM
Feb-02-2016 04:14 AM
Feb-01-2016 08:05 PM
Reddog1 wrote:djg wrote:On my unit, I can adjust or turn off the humidifier. I used it with my single AGM battery.
Hey thanks for all the info you guys I know my batteries will hold it then, just maybe not use the humidifier , I assume you just do not fill or put the tank in to not use the humidifier. And again thanks for all the info this is a great forum love all the good info I have gleamed from it.
I find very little loss using the 100 watt inverter, but would use the 12-volt adapter if it is free.
I feel confident that you will have no problem running your CPAP machine with what you have. But the fact is just how much of your available AH do you now use? I will also add, if the AH available are questionable for a night orb two, I really doubt you will die if you do not use the CPAP machine for a few nights.
Feb-01-2016 07:28 PM
PatrickA51 wrote:Sometimes I use the humidifier and sometimes I do not. I really can't say I experience a difference either way.
I have humidifiers for my machines and do not use them. I was told that once I started using a humidifier I would never be able to stop.
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Feb-01-2016 07:16 PM
Feb-01-2016 06:47 PM
Toad: 91 Zuke
Feb-01-2016 04:19 PM
Feb-01-2016 01:29 PM
Feb-01-2016 12:50 PM
Feb-01-2016 12:39 PM
Tiger4x4RV wrote:
If your CPAP machine has a unit-specific 12V cord available (CPAP.com is a great source of info on this), and if your TC has a 12V socket near the bed, you'll be fine. This is assuming that the batteries charge while you drive. The factory webpage for your TC says it has 12V outlets, but does not say where they are.
Another option, which I used early in my CPAP days, is a small plug-in inverter and then run the CPAP from that. My little inverter is a Duracell 150W.
If you do not have your CPAP yet, ask your provider for one that will run on 12V.
