Sep-14-2015 05:30 PM
Sep-19-2015 08:46 AM
Sep-17-2015 07:58 AM
AH64ID wrote:
Sorry but Ram still uses 8x6.5" bolt pattern. 2013 is the year they added 18's to the HD lineup and they fit just fine on older trucks as long as the truck hasn't been converted to manual hubs. While most of the wheels have changed from 2010 to 2014 there are a couple DRW wheels that carry the same part number between those years.
To the OP you need to get to a scale. The 18's from a 13+ will only get you up to 7K with the wheel rating, thou the tire rating may be higher. Your 03 wheels and tires will get you to 6390lbs.
Sep-16-2015 10:48 PM
bbaker2001 wrote:
ok, I will ask before I buy.
just found a 2003 3500 ram
46000
in showroom condition
has done all regular maintenance
looking at 30 ft 5th.
where can I find the specs like GVRW and axle weights. I do not want to go over.
I want a 3500 because of cargo capacity, but I think the 2003 is not better than a 2500 2014.
is it still a good deal at 23,500
Sep-16-2015 08:05 PM
Sep-16-2015 05:56 PM
Sep-16-2015 05:31 PM
Cummins12V98 wrote:jus2shy wrote:
Huh, last I checked, my aam's were still 8 X 6.5 or 8 X 165.1mm. At least when I last looked at wheels for my truck.
Ok Rusty JC what is da facts here?
Sep-16-2015 04:20 PM
Sep-16-2015 04:19 PM
Sep-16-2015 02:39 PM
Sep-16-2015 01:33 PM
Cummins12V98 wrote:
Old-Biscuit has it right. You will most likely be over your rear tires carrying capacity.
A 16K 5er and yours will easily get there will have a minimum 20% 3,200# pin and easily up to 25% 4,000#.
So now you have a choice of blindly towing it like most will do or installing a set of much higher load range "E" tires from a new RAM or 19.5 tires and wheels or better yet get a truck that the new RV is within it's ratings.
Of course all JMHO!
Sep-16-2015 08:51 AM
Sep-16-2015 08:35 AM
Sep-16-2015 04:43 AM
Sep-16-2015 04:37 AM
SouthernLoCo wrote:
I pull a 2015 Jayco Seismic (dry weight of about 15K). I had a Dodge 2500 with firestone airbags, a Banks exhaust brake with the 5.9 Cummins. I had no problems pulling in OK, AR, TN, etc. However, Monarch Pass did the 2500 in! It got us home, but the tranny was shot. I loved this truck, but the tranny could not pull my heavy girl in the mountains.
I got home, and traded for a 2015 RAM 5500. Put a CM flatbed on it and B&W flatbed Companion hitch. The truck has the Aisin 6 speed tranny and I got 4.88 gears. My world is totally different now! Love this truck and feel much safer pulling with it. Pulls that 44ft fifth wheel like its a little wagon.
When I began the fifth wheel buying journey, I thought I could modify my undersized pickup and be okay. I was dead wrong. Get a tow vehicle that is more than you'll need. There is nothing more stressfull than having all your kids, two dogs, and gear on a trip. Then praying you'll make it home. I had to learn the hard way....
