Apr-29-2022 07:01 AM
May-02-2022 06:01 AM
May-02-2022 05:35 AM
larry barnhart wrote:
good to have you back shiner. chevman
May-01-2022 06:51 PM
May-01-2022 08:41 AM
May-01-2022 08:12 AM
Bionic Man wrote:rjstractor wrote:Bionic Man wrote:
How would it not burn more fuel when it has twice the displacement?
When I mentioned "naturally aspirated engines in pickups", I was referring to the V8s used in HD pickups produced by Ford, Stellantis and GM. Those engines are all roughly the same size as the 6.7L B-series Cummins, not twice the displacement. A modern engine's fuel usage is based more on power output, not displacement, especially under high loading. We'll have to wait and see what the specs end up being on these new engines. If they are less fuel efficient than the current gas pickup engines they will fail.
That still doesn’t make sense to me. Adding a turbo effectively increases displacement. When the turbo is spooling it would absolutely use more fuel than a NA similarly sized engine.
Apr-30-2022 06:54 PM
Apr-30-2022 06:23 PM
Apr-30-2022 06:02 PM
rjstractor wrote:FishOnOne wrote:Bionic Man wrote:Maybe it doesn't have a turbo.
Wouldn’t the fuel economy of a 6.7 turbo gas engine make almost unaffordable?
I would think it would have to be turbocharged to achieve power levels comparable to current naturally aspirated gas engines used in pickups. Otherwise it will have to be able to run at 5500 rpm or more. Maybe a Cummins B can do that but I doubt it. JMO, but I think it will be direct-injected and have smallish twin turbos. It will rev higher and have less torque than the diesel version, but have the same HP at lower RPM (more torque) compared with current normally aspirated gas V8s. There's no reason it should burn more gas than today's gas engines unless they crank up the boost to try and get 600 hp out of it.
Apr-30-2022 12:31 PM
Apr-30-2022 11:52 AM
Apr-30-2022 07:07 AM
Apr-30-2022 05:52 AM
ShinerBock wrote:Cummins12V98 wrote:
My question who would buy such an expensive Gas Engine???
With today's prices, I am not surprised anymore on what people will pay for stuff. Many will lay down $11k to go from a base trim package to a premium without batting an eye.
Although I don't think this would be nearly as expensive as the Cummins diesel. You would not need a lot of the emissions equipment which would reduce a lot of cost and weight. You would also not need iron heads, a VG turbo, as large of an EGR and fuels system. So there could be a lot of cost and weight savings in a gas version.
Apr-30-2022 05:44 AM
Apr-30-2022 04:10 AM
