โApr-29-2022 07:01 AM
โMay-10-2022 07:47 AM
ShinerBock wrote:
It is not necessarily the fact that emissions systems on gas engines are figured out, it is just that the US EPA has a hard on against diesels and therefore have stricter requirements on diesels. Even though gas engines are more harmful to the environment due to their inefficiency and today's direct injected engines emit a lot of particulate matter, diesels emit a lot of NOx which is only harmful in very heavily populated areas. In les populated areas, NOx dissipates into the upper atmosphere and gets turned into a good thing since NOx is a helpful greenhouse gas which is also created by lightning, forest fires, and many other heat sources.
So, it is not that they just haven't gotten diesel emissions figured out, it is just that they keep getting stricter and stricter because the activist powers that be seem to have a disdain for them. If you look at all of our emission requirements and fuel economy test standards, they are all made to get the best possible outcome out of a gas engine, not a diesel or CNG vehicle. Although, after the SCR/DEF systems, they have been getting a lot better.
โMay-10-2022 05:36 AM
JRscooby wrote:ShinerBock wrote:
Back in the day, I had the most powerful gas engine you could buy(plus mods) in a truck to tow my 8k lb trailer. Truck had a 4 speed and after one trip towing through the Texas hill country, I traded that truck in for my first diesel. I am not saying that the truck could not pull it, it just didn't do it to my preferences and expectations. Of course, everyone's preferences and expectations are different though.
So, don't get defensive about the "My trailer is too heavy for gas" (which is not what I said). I just said that diesel is the only way "I"(as in me, myself and I) would go with "my" trailer. Not saying a gas couldn't pull it, just that I wouldn't want to be driving any current gas engine HD to do it. If I had to pull it with a gas truck, then I would probably go with a Ford 7.3L unless this Cummins 6.7L gas engine comes out and it is turbocharged.
None of my 427s where built. I would call the parts department at GMC dealer, load new, not rebuilt, but new engine in pickup, and change it in a parking lot. All same as what was installed in new twin-screw trucks.
Now I was stopped for overload, driving a diesel, at age 14. But 6 years later, buying my own truck, I bought what I could pay cash for, worked it until I could upgrade. Hauling asphalt, first truck to plant got first load, and first truck to paver, first unload. Near a roadrace, grossing over 30 tons. All the 671s and some of the 871s could load behind me all day long. Now when we hooked up the pups I was EZ to pass.
My point is with the technology available back then engines burned gas, and moved what needed moved. Coupled with the fact that emission systems on spark fired engines are pretty well sorted out, and compression fired is not, I can see light duty, (less than 30,000 gross) might be better to use gas.
โMay-09-2022 03:58 PM
ShinerBock wrote:JRscooby wrote:ShinerBock wrote:FishOnOne wrote:
I think cummins see's the writing on the wall for the future of diesels in this market segment and the trend of more Hemi's replacing the cummins (My observation) so as a company they have to evolve.
Also I don't see Stellantis' designed 3.0 gas engine making it to the HD duty line up.
I think the fact that there are more gas engines in the HD segment than there used to be is not limited to Rams. With today's more powerful gas engine options and more gears, I see a lot more gas engines in the HD segment of all brands than I used to to. Of course, most of these are the guys that really didn't need a diesel to tow what they do and only had diesels before due to the dismal performance of the older gas engines. If I only had to to tow 10k, then I would likely have gotten a gas HD over a diesel. With my trailer, diesel is the only way I will go.
If I could of made a living running 20,000 miles a year I would of parked a 427 GMC the day I retired. As for "My trailer is too heavy for gas" back in the early '70s I would haul a load every day where my GCVW was about 55 tons.
โMay-09-2022 03:55 PM
โMay-09-2022 03:08 PM
mkirsch wrote:
sent PM
Any GMC Twin-Sixes?
โMay-09-2022 07:17 AM
โMay-09-2022 06:33 AM
โMay-09-2022 06:15 AM
โMay-09-2022 05:33 AM
โMay-08-2022 09:17 AM
โMay-08-2022 05:38 AM
โMay-07-2022 08:43 AM
โMay-06-2022 03:17 PM
โMay-06-2022 02:54 PM
