โMar-18-2021 06:41 PM
โMar-29-2021 05:20 PM
โMar-29-2021 03:45 PM
โMar-29-2021 03:44 PM
JimK-NY wrote:
I wondered about painting. Seems like the usual Krylon or Rustoleum paint would not last very long. I am not sure what Torqlift and others use but I would guess a powder coat or baked on enamel not some home spray/paint application. Or just let is rust.
โMar-29-2021 03:21 PM
Kayteg1 wrote:Bert the Welder wrote:
Did you up-size the tube with a couple sections/sleeves of larger dia. tube or ?
And any reason for not going w/ the larger tube that fit the receiver tubes for the whole thing? Did you have the off cuts laying around or was the larger tube 10x the price?
I used the junk I had in my garage.
My hitch tube was 3" from what I recall, so old 2" receiver tube and then old ball holder from what I remember brought me 1.5" hole for long tubing.
The tube adapter doesn't have to be build from tubing. You can cut flat plate to size and weld the shims around.
As for making whole tie-down from 2 or 3" tubing, the tie-downs as experienced by several members act as weak point.
When you hit a bump at high speed, I rather will have to deal with straightening the tie, than with repairing camper anchoring point.
โMar-29-2021 01:58 PM
โMar-29-2021 01:50 PM
โMar-29-2021 12:27 PM
Kayteg1 wrote:
Home Depot carries square tubings.
Sound like you are talking about front tie-downs, when as I mention, rears are 1-2 hr job.
Here is picture what I did. 3" sill washer from HD on the end.
Click For Full-Size Image.
โMar-29-2021 12:20 PM
โMar-29-2021 12:17 PM
โMar-29-2021 08:33 AM
โMar-29-2021 08:06 AM
โMar-28-2021 11:05 AM
burningman wrote:Bert the Welder wrote:burningman wrote:
Are you guys for real?
These are extremely simple metal fab, not rocket science.
I made my own and theyโre a better fit for what I needed than anything Torklift makes, and easily as strong.
Iโm not knocking Torklift, they make great stuff.
Iโm knocking the people who think no one can or should do anything themself.
Sure. If someone can build a dog house, then they must be able to build a full size house. Makes sense.
So yeah, just go grab any old Harbor Fright welder and start blazing away. Beside, there's always a grinder and paint to make it 'look' good. :S
Thatโs not the comment Iโd expect from a guy who calls himself Bert the Welder!
I didnโt say โif someone can build a dog house they can build a houseโ, itโs easy to try to make someone sound crazy by quoting things they never said.
Camper brackets - as you should know judging by your user name - are extremely simple. Seriously anyone with a Harbor Freight welder and a chopsaw could build them.
And sure, you could do a horrible job and scree them up.
You can also be a horrible driver and wreck the truck.
โMar-25-2021 04:27 AM
โMar-25-2021 03:48 AM
โMar-25-2021 02:52 AM
Bert the Welder wrote:mi.drew wrote:
Belly bar clamped to the frame for the front. Tubing run through the frame cross member at the wheel well for rear.
"C" clamps or "F" clamps?
