โJul-15-2016 02:19 PM
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โJul-16-2016 06:20 AM
dedmiston wrote:
Interesting consensus from all of you on the exhaust brake. I use it whenever I tow, but rarely use it otherwise. It seems like the exhaust brake scrubs off enough momentum on the downhills to negatively impact fuel economy. Maybe that's in my head though.
What about DEF usage when towing vs. not towing? I don't really notice the gauge drop very much, but it seems to drop quicker when I'm towing. I can't tell if that's real or if it's just in my head.
โJul-15-2016 10:54 PM
โJul-15-2016 10:00 PM
โJul-15-2016 09:45 PM
FishOnOne wrote:
Perhaps you did explain it but I'm fully aware how these systems work and the problems they have. Having said that, my '12 uses more EGR than my 05 Powerstroke, but the fix to the sticking vains was a simple one and that was to cycle them while the truck is idling. I can actually here it occurring on my '12 since the engine idles so quite.
โJul-15-2016 09:18 PM
ShinerBock wrote:FishOnOne wrote:
I change the oil between 5,000 - 7,500 miles.
Oh, that is why. I can go about 5,000-6,000 miles between DEF fill ups. But no where near my 15k mile oil change intervals.FishOnOne wrote:
The 6.0 PSD I had never had the turbo touched, but I did replace the EGR valve at 80k miles and cleaned the EGR valve at 160k miles due to soot clogging the valve. The symptom is the truck would run sluggish and blow black smoke at low rpms.
Soot on the VGT vanes was a common problem with the 6.0L. So common in fact that even PowerstokeHub lists it as on of the issues of the 6.0L.
6.0L POWER STROKE PROBLEMSFishOnOne wrote:
I've yet to hear of any vains getting stuck on the 6.7 PSD. My '12 requires to have the truck running in Tow/Haul mode for it to work, but I don't like to run it in this mode while driving around town.
That is because the SCR/DEF system. Since your truck is equipped with a SCR/DEF system, it does not need to utilize the EGR as much to reduce NOx creating less soot. Since the 2007.5-2012 Cummins did not have an DEF system, the EGR was over utilized to meet emissions which created a lot of soot. That is of course gone with the addition of a SCR/DEF system on the 2013+ Cummins trucks. I thought I explained this to you a few times before?
โJul-15-2016 08:49 PM
โJul-15-2016 08:28 PM
I add DEF fluid at every oil change which is typically 2 gallons using only DEF from a container and at 96k miles no issues to date. And for the naysayers it doesn't mean I would have problems using bulk DEF, but I'm just more comfortable with the container stuff.
You only fill up every oil change? How often are you doing your oil changes. There is no way I could go 15k between DEF fill ups.FishOnOne wrote:
Running exhaust brake is still a common practice on the 6.7 cummins to prevent soot build up in the turbo
LOL!!! Too bad the 6.0L Powerstrokes didn't have exhaust brake to "clean the soot build-up" on them since they were prone to soot build up on the VGT veins. I wonder if you have to run the exhaust brake on the new Powerstroke since it is VGT now too.
โJul-15-2016 08:27 PM
โJul-15-2016 07:49 PM
โJul-15-2016 07:13 PM
โJul-15-2016 06:19 PM
โJul-15-2016 04:33 PM
IdaD wrote:The reason it is like that is certain road condition can be dangerous with the EB activated.Me Again wrote:
I wish one could default the exhaust brake to be on all the time. When towing it restarts in Tow/Haul but not exhaust brake.
Ditto. I often find that I drive a few miles before I remember, and I'm going to wear the stupid switch out because I have to turn it on every time. A minor quibble but I wish it would remember the last setting before you shut it down.
โJul-15-2016 03:48 PM
