โJul-07-2014 04:51 PM
โJul-09-2014 04:06 PM
โJul-09-2014 01:57 PM
bud121156 wrote:
I was more concerned about the engine turning ~4000 RPMs going up the mountain. I backed off, and kept the engine closer to 3000-3200 and was much more comfortable.
โJul-09-2014 01:28 PM
opnspaces wrote:
I've never driven a downhill like that with the 20mph turns but I can see how that would heat the brakes up. Were the truck brakes starting to act funny that prompted you to use the trailer brakes alone? Just wondering because it seems that if the trailer brakes will fade faster then the truck it would be a mistake to use them alone to also slow the truck.
โJul-09-2014 12:51 PM
โJul-09-2014 12:31 PM
โJul-09-2014 11:04 AM
brulaz wrote:
One more thing, if you're going down a hill with lots of sharp 20mph turns, that can be a lot harder on your brakes than a steeper, but straighter and faster descent like on the Interstates.
And the drum brakes will fade faster on your trailer than the disk brakes on your truck. The trailer brakes will need constant re-adjustment via your controller as they heat up. On the western descent with all the hair-pin turns down the pass in Great Smoky Mountains N.P., I kept increasing the voltage to my trailer brakes as they heated up so the trailer would keep doing its part. I also started manually operating them to give the truck brakes a break. That was all in 2nd gear. All the brakes were stinking hot by the time we got down. Probably should have pulled over to let them cool.
โJul-09-2014 10:10 AM
โJul-09-2014 09:09 AM
sacmarata wrote:proxim2020 wrote:Passin Thru wrote:
BB is 6% for 5 miles, some interstates are 9%, but no more out west. Never saw anyone descend up a mountain!
All "interstates" must be AASHTO compliant and restricted to 6% grade. Waiver can be issue from the Federal Highway Administration for mountainous regions, but restricted to 7% with speeds under 60 mph. The Eisenhower system is designed to move military equipment across the country quickly and efficiently. When moving heavy or sensitive equipment, grades are important.
Are you a state highway official?
โJul-08-2014 02:59 PM
โJul-08-2014 02:24 PM
โJul-08-2014 01:24 PM
BurbMan wrote:
Use your tow/haul button and watch the speed limit on the road. If you shift manually to 2 it will hold your speed to about 45 mph. Drop down to 1 and it will limit you to about 30, no matter how steep the hill is. but that engine is gonna rev! If no sharp curves, I would put it in 2 at the top and let it go. Tap the brakes as necessary. If you see signs for sharp curves, you can brake to 25 or so and drop into 1. Try to use the brakes as little as possible, and watch the trans temps as you descend the hill.
โJul-08-2014 01:18 PM
โJul-08-2014 12:58 PM
โJul-08-2014 12:55 PM
