โJun-21-2004 09:12 PM
We are getting closer to answers I am looking for etc.
โNov-14-2006 07:02 PM
BertP wrote:Jackjagt wrote:
I mean Diesel compared to Gas rigs. The explaination holds.
Your rig's max torque will be at a lower RPM, and thats where you will accelerate or climb fastest. You'll probably turn even lower RPMs at cruise on the level, but in high gear.
Of course at 3000RPM it certainly will sound like it's working harder!
You acellerate hardest at your engine's max HP point, not its max torque point.
Bert
โNov-14-2006 06:56 PM
BertP wrote:DavidPhillips wrote:
The diesels max power output is at lower rpms (see above). The force is what maintains speed.
And there is the main problem with your argument. My DMax generates its max power at 3000 rpm. You are confusing torque with power.
Bert
โNov-14-2006 06:55 PM
โNov-14-2006 06:47 PM
Bert
โNov-14-2006 05:21 PM
Jackjagt wrote:
Torque is what gives you your acceleration
Jackjagt wrote:
and pulling capacity.
Jackjagt wrote:
HP and T go hand in hand. As the rpm's increase for a given torque, the HP must also increase, and as the HP increases for a given rpm, the torque must increase.
Jackjagt wrote:
Usually, in my engineering calculations, I determine what Torque I need at a given speed, and that gives me the required HP.
Jackjagt wrote:
Usually the max Torque and HP are determine by the required acceleration from zero to a certain speed. E.G. how many seconds do I have to accelerate this load (machine) from zero to, say, 1000rpm (which will represent some Feet-per-minute (fpm) machine speed).
Jackjagt wrote:
Our diesels produce LOTS of torque at lower rpms. That's why they are geared differently than their gasser cousins... to take advantage of that torque.
โNov-14-2006 05:13 PM
Jackjagt wrote:
The rig with higher torque will reach the top of the hill first. On the level their top speeds would be the same, but the higher torque rig would get there first. IMHO
โNov-14-2006 05:09 PM
โNov-14-2006 05:08 PM
โNov-14-2006 05:02 PM
So Jack what's your opinion on the subject?
Two vehicles towing heavy rigs. Both have 300 HP.
Both pulling same weight. One has higher torque.
If the hill becomes very steep is it possible for one of the vehicles to slow down and the other keep going at the same speed even though they have the same horsepower?
โNov-14-2006 04:55 PM
โNov-14-2006 04:42 PM
โNov-14-2006 04:32 PM
โNov-14-2006 04:19 PM
โNov-14-2006 03:41 PM
Commonly refered to as the power band, the rpm range where an engine makes at least 75% of its maximum torque.
OK, let me be more specific: What do you mean by "use up some force in the driveline" and "lower output from the engine at the point in time that it is out of it's peak operating range"?
Diesel engines have their torque peak quite low in their speed range usually between 1600-2000 rpm. This allows the diesel engine to be given higher loads at low speeds than a gasser.
What difference does the rpm make? We have transmissions to compensate for the lack of power at low rpm and both gassers and diesels need them.
We already agreed that enough resisting force would cause a vehicle to downshift. At some given resistance the diesel will not downshift and the gasser will. This is due to the greater force of the diesel.
BertP wrote:
And? What difference does that make?
Bert wrote:DavidPhillips wrote:
It looks like you already agreed to that as well.
BertP wrote:
Yes, we did.
It seems pretty clear to me, but I will try to elaberate.
An engine outputs more force in a certain rpm range also refered to as it's power band.
Even if it stays within that power band all of the time the power band
has a high point somewhere along it. When they rate an engine they give max values. At other rpms than the point where it is at the max output you will not get max output.
If you are dropping in and out of that rpm then the overall output of the engine will be lower than if you could run in one gear and maintain the rpm where the maximum output is.
So if you are changing gears you are droping into a lower part of the power band with a gasser.
Since a diesel's max power is always at its max rpm point, the shifting you are referring to will adversly affect a diesel more than a gasser. Be that as it may, though, what difference does it make? We have to have transmissions.
Bert
