Oct-11-2018 08:09 AM
Oct-12-2018 01:41 PM
Oct-12-2018 12:28 PM
Oct-12-2018 11:52 AM
Cummins12V98 wrote:LIKE2BUILD wrote:SidecarFlip wrote:
Only thing I wish was my stock cover (Corporate 10.25) has a drain plug in it. ....
You could remove the gear oil with something like this Topsider Fluid Extractor.
Personally want to look at the condition of the gears and get all the lube out.
Oct-12-2018 11:49 AM
charwan wrote:bobsallyh wrote:
Over the years I've been a fan of looking at rear ends, but not finned aftermarket covers.....
I was a Ford mechanic for years and worked on many a rear end....Never saw but one rear end burned up....Waste of good money.
Oct-12-2018 11:32 AM
ib516 wrote:Groover wrote:
I find it interesting that the entire discussion so far is concerned with keeping the differential cool but Ram recently added a differential warmer on some trucks. Overheating is bad but so is overcooling. Finding the sweet spot for your application is the trick.
I think they added the rear diff heater for mpg reasons for times when the very viscous gear oil is cold - not sure where you're from but where I'm from, 80w90 gear oil is like a bar of soap at -40 and will rob mpg until it reaches operating temp. When we see the data from Banks on the running temps of gear oil, I suspect it will be higher than running temp of the coolant, or maybe RAM has a way of turning the coolant flow to the rear diff on and off depending on temperature.
Oct-12-2018 09:01 AM
Oct-12-2018 07:59 AM
Oct-12-2018 06:38 AM
Only thing I wish was my stock cover (Corporate 10.25) has a drain plug in it. I have to pull the cover to drain mine, something I do every couple years.
I bought one to use on my boat to change the oil, but it works great for remove diff gear oil as well. In fact, I've found several different uses in the garage so it's a pretty handy tool to keep around.
Oct-12-2018 06:21 AM
Oct-12-2018 06:16 AM
Oct-12-2018 04:54 AM
Over the years I've been a fan of looking at rear ends, but not finned aftermarket covers. Can someone tell me how long the rear differential in our 2003 Dodge dually is going to run with 242,000 miles on the clock with the plain old OEM cover towing a 40' fiver?
I was a Ford mechanic for years and worked on many a rear end. What you said bobsallyh is very true. Never saw but one rear end burned up and it was a F350 were a boy got stuck and burned it to a crisp. Waste of good money.
Oct-11-2018 06:47 PM
Oct-11-2018 05:59 PM
Oct-11-2018 02:35 PM
Oct-11-2018 02:25 PM
